SIKDMAX LMM painfully slow Install/Build Thread
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Heres the rest of it.... front and rear. The front coolant pipes I assume need new gaskets, I cant find em from the old stuff so I guess I need to buy new... anyone know part numbers?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I removed the stock pipe
I kept the flange
i installed a thicker tubing and crimped a fitting on the end of it to adapt to A/N
I then ran a braided hose to the turbo
9,903
149
Have you got a pic of this Simon? It might help him understand it a little better. IT really is a simple set-up that works quite well!!
LBZrcks
Jun 2, 2007
5,297
12
SoCal
wait the LMM driver side uppipes are different??? :confused:
How come it has an LB7 rear cover?
Does it look different to you Ben? I never paid attention, but if a LB7 riser pipe will work then I have one.
Like Jordan said he broke the rear cover pulling the motor.
ripmf666
15,123
14
47
Wentzville Mo
Also run the one harness going to the oil pan now its easier remove the water Y bridge runs behind that an dthe little hard line and rubber hose off black tube from water pump
13,715
779
why not??
i know htt upgrades the 66's to 71's quite often, lots of dodge guys running them
Because he originally thought it was a 66, but he saw something that made him think it was a 71. I got my 66mm HTT yesterday, so if it was one of the tags, I was going to see if I could help him figure out what he has.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
I bought it from Pat who said it was a new 66 SS. Sweet!
But then as I was playing around with it... I saw this:
Now... Im no dummy but MOD for Model.... HT High Tech SS Stainless Steel 71 71mm?
I know they make them in 66 and 71, so it only makes sense.... right? :confused:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I dont think its a bad thing that you got the 71mm , you might like it as a single and maybe twinned ! time will tell ................
IF you really want to know just measure the exducer , it should read 71mm .
