I know LB7/LLY blocks are the same. But what about putting LLY heads into an LMM? Possible? Impossible? Or am I stupid?
It would work fine. I have a friend who used an LMM block with LB7 heads,timing cover, fuel system etc.
So Jason, do all the passages in the LLY heads match up the the passages in the LMM block?
not sure why he would want lb7 heads?
im working on lb7/lly block to lbz heads(injectors)
'Corrected"
Ok so than you will have to change the reluctor wheel and the front cover to the 05 parts. And you will have to change the oil cooler adapter to remove the EGR cooler hose fitting.Ok I got the details on the block.
The block is an 09 LMM that a set of 05 LLY SoCal stage one heads would be bolted onto.
This would all be put into an 05 GMC Sierra.
