second gear launch
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
so let the trans get into 2nd (after clunk) before boosting.....check
only boost up minimal amount of time.....check
do not hot lap.....check
The easiest way to be sure you are in second is to give it a little throttle while you are rolling up to stage; once you hear and feel the clunk hold that slight throttle and use the brake to pull the rest of the way to staging, that way it doesn't go back in 1st.
It will also clunk every time you stop and go getting to the lanes. If for some reason Pat doesn't flash it before I leave the track. The kids are like Mom will you get Dad to flash your truck :eek:
You can also only delete 1st from T/H mode, then when you are in normal mode you have 1st back and there's no clunking in and out of 2nd. As long as you aren't towing heavy you can daily drive on the tune as well.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
I don't run T/H in Wendy :D She is slower.
