If all you change is to a single pump, you only hurt common rails. P-pump will rule that class.
There is no easy solution
I think that would be an excellent class to improve diesel technology where it will do the most good. Factory untouched turbos, factory single pumps. Screw the cross-bolts and hoops.
I would love to see true WS come back.
Yes, but that was everyone at one point.
Two "first time" pullers took less time combined to hook & pull than it took one single SS truck to hook, spool up, then pull at the AV pull. So it's not just the newbies that chew up time.
To add to Pat's comment on progression...
My brother is new to the sport (doesn't own a pickup yet, but wants a Dmax ) and went to a couple pulls with me this year. He mentioned to me the other day, after telling him about Scheids, that he would like to see something similar to what Pat is talking about. He said to leave the sled the same weight for the different classes (maybe stock, workstock, 2.6, 2.8) to get a sense of the power that the mods on each truck are making. You could see the progression with the distance in plain view.
To add to my previous comment about Scheid not wanting to deal with off the street trucks...with a 2.6 rule like was in place it was definately geared toward the experienced puller. That would, in my mind at least, eliminate some of the responsibilty of the track crew so that they could make sure the show runs smooth. Iirc, there was not a driver's meeting out there either.
I agree that they need a true workstock class though, don't forget what got you to where you are.
On a good WS truck we can put 20 to 40'I don't believe that would be the case. Twice the HP won't move the sled twice as far.
Basically we were discussing the rules eliminating the stock charger/daily driver trucks, Dmaxs finishing wellVan Haisley's claim of 900 hp to be competitive in 2.6, the sled breakage, TNRGreene's carnage, and Troy Wakeman's unique sounding truck.PHP:even if the rules favor cummins powered trucks,
Cliff notes
Now thats some funny stuff right there........
The reason for WS changing to a 2.6" turbo wasn't because the 6.5's and 7.3's weren't competitive with stock chargers.
What do you think the reason was?[/QUOTE
IMHO the main reason I see was to limit the amount of class's.....
