S475 TCT single
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I finally got her nestled right where I want it. After head studs, and new grade c's, filter head delete, and a new 850 hp rated south bend dual disc she's with in a few days of a test drive. Ecm is getting updated at duramax tuner. My custom pedestal is done. Waiting for my exhaust v band so I can make a 4 inch down pipe. Then make a 5 inch intake and I can take her for a test drive and see how low in the 12s my new custom short throw will put me. I honestly can't wait to see what this thing has when it's done. I did just get a go pro so I'll keep u guys posted. I have a lot of little thing to do to get her ready for next year.
picture.php
zf>allison
Apr 30, 2013
3,394
elsberry mo
BTW anyone have any idea on a hot side adapter boot to go from the race cover to the hot side pipe? I thought I could extend my hot side with a piece of 3 inch aluminum and weld a bead around it? it's all 3 inch after the necked down part of the pipe correct? I'd be cutting the necked down part off and replacing it. Or is there a boot I can buy?
zf>allison
Apr 30, 2013
3,394
elsberry mo
Building this saved me a wad of cash minus the up pipe flange (thanks rick) it did just what I needed it to. This was before I painted it black. It was fun and makes me that much more proud of the project. I can't wait to make my air box and Intake piping.
picture.php
Dirtymaxx03
3,109
You gonna run the stock hot side stuff? I did with my 472 and just bought the vband and a reducer on race parts solutions. Welded them together and it's been working great.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Maybe we're talking two different things the outlet on the turbo is a boot style it's just to big for the hot side pipe. I'll need Luke a 45 degree 3 inch to 2 1\2 inch boot. I think, as long as the measurements are right.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Ahh....I just assumed you had a V-band outlet, because that's what most race covers come with. You might just want to buy a new hot side intercooler pipe, most aftermarket one do away with the long sweeping boot and are 3" dia all the way.
zf>allison
Apr 30, 2013
3,394
elsberry mo
The outlet of the compressor and hot pipe should be the same size, 3".
They stock hot side I believe is 3" but it necks down at the top about 3 inches or so from the end. I wish I could buy a hsp hot side pipe but I'm trying to be budget friendly because I have a daughter due halloween. So I'm making everything i can.
