Lookin good russ
Hey, look who came out to play... It's been a Long time:hug: Thanks!
Lookin good russ
You can't just go build high flow runners..you have to build the whole system and this is just one part of it. You need runners pedestal y bridge etc all of which russ stated he's working on. This is just a sneak peek . Also put a pressurized substance such as n2O through a stock y bridge and see which way it flows. I'll tell you it's definately not even so yes it does matter.
Yes you can.
How do you know which way it flows? you have a see through y-bridge and underhood camera?
It will follow the path of least resistance. In a pressurized system like a turbocharged one, that path is through the valves. The intake manifold does not influence the flow.
Yes you can.
Actually you can. Forced induction, read up on it. The only thing it doesn't like is restriction and bad cam design for it's purpose.
Be interesting to see this piece on an engine dyno for comparison.
Actually you can't, simply because it won't fit if you don't change the system.
Didn't I say the CP3 had to move? That is not a system change but a pump relocation. Saying you can't is giving up. Never get anywhere saying that.
I have sprayed C02 through an LB7 bridge when removed from the truck, and it does favor one side.
If you did finally find a way to make a set of low-rise (read: within stock or near stock size so turbo is left alone) intake runners, wouldnt you then have to worry about the size/length of the runners themselves? Or doesnt that matter on a positive-pressure (boosted) intake system as compared to a n/a (suction) one?
Cp3 shouldnt be an issue, would it? Wouldnt you just run it in the dual-alt space, and if want to run a second Cp3, you run it like Rob and Ken did on Max'd Out?
EDIT: Tiago (SIK LMM) has agreed to try a before/after Dyno with his truck.
Good idea Mike, I think I have an LMM (Anthony or Tiago) that would sign up!
I'll ask again, since it was ignored earlier....
First thing I see in the way of larger runners is the turbo, and the other end is the CP3. I would say get the pedistal changed to allow larger runners, and either delete the valley CP3, or make a minor change there.
I have sprayed C02 through an LB7 bridge when removed from the truck, and it does favor one side. The LBZ bridge looked like it flowed the same.
Tom, boost does not require equal length runners. It just needs more area in our situation. The turbo realisticly needs to be moved as well as the CP3.
