Balance rates
+-4 at idle in park
+-6 at idle (foot on brake) in drive.
If you're reading balance rates your way out of spec.
+-4 at idle in park
Balance rates
+-4 at idle in park
this is wht it looks like in efi notice 7-8 are high. the rest are real low
I would also be concerned about 2, 4 and 5
How do I find out for sure? Will it do more damage if I keep running it? I thought the LB7's were the bad injector plagued group of engines.
Truck still seems fine today but I turned the tuner off completly. The injector rates are averaging around PW 8.0ms at idle in gear with foot on the brake. Am I reading the right thing? And if so what should I do now?
I'd have a hard time believing all the injectors are that far off. Have someone with efi or as Kat mentioned a tech 2 check balance rates.
Sounds like an injector is sticky at times. Run a bunch of power service or equivalent.
i dont hink you reading injector rates it should be the only thing on the tuner tht has 1- 8 and should day inj with + or - i havent looked at ppe tuner in a while to telll u for shure
Its the only thing with a 1-8 on the tuner No + or - though.
Hmm well if my truck wasent in a million peices i would go check for you.
tech 2 or efi is much easier to read as well see wht you can track down
My ppe does not look anything like your predator display but I definetly appreciate you taking the time to post it. I will take a pic of the PPE display tomorrow and post it. Updated my sig and location.
I sold my PPE Hot+2 ET on here to a guy and when on the LBZ it reads the rates they way it should, When he went to read the lly would not do it all high numbers like you he call Dan and said that it will not read the rates on the LLY you need efi live or a tech2.
