Riddle me this..
paint94979
Beer Nazi
Sep 18, 2006
11,715
You had better be charging Brian for the tech support calls Mike :D... The tune of 1000$ per call sounds about right
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
On and off the pedal causes a pretty big load on the transfer case gear train. I see it a lot on 47RE Dodge trans extension housings.
Ah, gotchya. Thank you. Presumably, more common in dodges because they have more low end torque? So a duramax built to produce more low end torque would be more susceptible to this given the driver is binary..correct?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
or it is different material
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I was just referring to the geartrain shocking...i guess I've been lucky to have customers that aren't chowdaheads enough to beat the piss out of their trucks. Lol. Although, the one tcase i have seen destroyed by driver abuse, was completely destroyed..not even rebuildable
5,920
Brian if you do it on a weekend, lemme know. I wanna peak inside as well so i know what im lookin at in mine when i do it in a week or two
15,681
I think the magneseum case is pretty soft on our TC's. On the Dodges I think it's the engine tq. I had a Dodge in last week that wore out the snap ring but the extension housing groove was fine.:confused: Gear train was moving back and forth. Washers were wearing out.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Pulled the internal filter, opened it up and here's what I found. Bottom of trans pan had same "metal" material on the bottom.
Loading up the Colorado on a Uhaul trailer and headed to Mikes monday morning. Been to hell and back with this truck :eek:
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Is this the trans in the colorado:confused: Reason i ask is because you said your loading the rado on a Uhaul trailer and not the dmax. Or are you just rolling the dice and hauling the rado to mikes with the dmax and hoping you make it there and then driving the rado bad home? Goold luck with your journey to Cali i hope everyhting gets panned out with your allison it has been painful just reading the troubles you have had with it. Maybe a fresh trans is what was needed anyways. Atleast you will know what you have now:thumb:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
This is the GMC trans.
Im dropping off the GMC at Mikes and then driving the Colorado back to PHX, then in reverse order when it's done LOL
gmduramax
Shits broke
Jun 12, 2008
4,082
252
Nor cal
;) I was right
