Repower LB7 and Duraflite
paint94979
Beer Nazi
Sep 18, 2006
11,715
With the PCS its around 12,000$ IIRC without the PCS its much less... Remember that's with buying a fully built race trans from Suncoast as well.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Yeah if I where to get one I would go without the PCS. I have thought about selling my SC V and having my 2WD Allison built but maybe for a long term course I would be better with a Duraflite.
S Phinney
4,008
Quncy, Fl
I was quoted mid 13k for it. If you had a core you would save 2k. I am sure a good competitive truck will end up somewhere in the 70- 100k range.
Sent from my XT1080 using Tapatalk
S Phinney
4,008
Quncy, Fl
Have you seen or thought about buying Bean's 80 model C10 drag truck? It's very light, can easily house your engine and already has a built 4r100 (same as Brett is running in his c10) has a proven chassis with good rearend, yada yada yada. Cage has 8.50 cert IIRC.
I was gonna try to buy it but found out my ol lady was pregnant 1 wk later so I bailed. LOL It's currently setup for a CR cummins but when I inquired about it, they had no problem exchanging the Dodge/4r100 adaptor for a GM/4r100 adaptor and even got them to accept to build and mount my dmax (not take care of getting it running, just physically get it mounted in the truck) if I paid asking price at the time ($15k IIRC). That's a pretty damn good roller to start with for the money.
It would need headlights and some other things re-installed to be streetable again but it does have a good title if street driving is a requirement.
Haven't seen the truck. Is there a thread about it? I was really looking for a certain style/look to be truthful.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
It is going for a screaming deal for sure. Love watching the truck run!
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
I vote yes....
IdahoRob
Jun 5, 2007
1,151
The PCS is like EFI. It is a tool, if tuning is set-up properly and the tranny is built well then it works great. I have had zero issues with the PCS/Valve body that suncoast supplied many years ago.
I takes a little bit to dial in, but really not tough. Our duraflite's are working great at our HP, I pulled the one apart from Max'd Out after breaking a 5 year old intermediate shaft and the clutches/bands looked brand new. This was after basically a full race season.
That being said if running a duramax in a light weight car/truck (<4000lbs) then I really look hard a 4l80. There are a lot of high powered cars running them and no adapters needed, bolts right up.
SmokeShow
6,818
Lawrenceburg, KY
If it were me, I wouldn't use a modern pickup due to weight. Their frames are more substantial and all parts are heavier. If you want correct style body for a dmax truck (01+) then I'd think about a fiberglass shell and a purpose-built chassis.
Sounds like you have a pretty healthy budget if you're entertaining this at the assumed cost of $75-100k. For that kind of cash, I'd just have Russ or Jeff Dean build me something and pocket the other half of that estimate. :thumb:
Bean's truck is listed on CompD and I'm pretty sure its still on RacingJunk too. I don't see how you can get all that truck has to offer for any better a price. So unless you're hell bent on building something from scratch, I'd get that one or at least some other rolling chassis that's already built. You can get them for about 1/4-1/2 of the cost to build one from scratch. That's coming from a broke tight ass that will likely NEVER be able to entertain a $75-100k build of anything though. :eek:
On edit: I'm almost positive Bean's truck is listed for sale on here too by member ctdiesel99.
Edit 2: Nope, it's not posted here. Sorry.
S Phinney
4,008
Quncy, Fl
I am just tallying up what I have already in the engine and accompanying supporting items and what it might cost to get the rest right and that us were I was thinking that much money. I am sure I could do it for less but wanted to be more realistic. I do most all if the work except transmissions and the turbo piping. Rob what would it cost for you to set up the PCS since you have the bugs worked out by now? I am sure I could get it going good as well. Beans truck looks pretty killer there. I will look at it as well.
IdahoRob
Jun 5, 2007
1,151
If your goal is consistent 8's then I'd follow Mitch's opinion and purchase a proven race car/truck as a roller, maybe look at a 7.5 cert rig, as 8.5 may not be enough down the road if the stars align. To build a unit from the ground up will take a lot of money and time, it can be done though. You can save .50-.75 on a dollar purchasing a good roller. I recommend as light as possible for what ever class you want to race in. 8's will be a challenge, but with the right stuff it can be done. If you don't mind not having a door car, then a rail would be a great choice.
I'll hook you up with the programming if you go that route (duraflite)
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Keep in mind a 7.50 cert rig needs to be under 3200lbs or it needs to be a 25.3 7.50 cert (bunch more tube/work). And anything over 3600 can only 8.50 cert iirc. Choose a platform you know you will never grow out of the first time around..
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
The NXEXPRESS DMAX MUSTANG I know runs the 4L80E, so if you get teh weight down it is definately an option for ALOT less coin. If you swapped over to LBZ electronics, you could even factory integrate the LBZ T42 TCM combo together uisng van wiring pinouts and operating systems.
1,941
So the rack and pinion is to high and will need relocating? That us the reason I am asking for experiences so I do not make some mistakes others have made. Thanks
Yup. Firewall would have to be modified to raise and move back engine to clear the rack. Not sure how far you want to go, but its a PITA to me.
Look at Thunder550's build thread on why the 4wd frame would be smarter choice.
Box/linkage steering, torsion bar suspension (easier to swap to coilovers ;)), engine can sit in normal spot.
You can also retrofit larger police/tahoe OEM brakes to the 1/2 ton front spindles, but you need to run min 17" wheels.
