removing tire sensors
b.d.keathley
118
Des Arc Ar
Got a buddy who has a 2014 duramax 4x4 and wants to take off his tire sensors. Is there any way to eliminate the light code on the dash?
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I know an h&s can on a newer dodge.. Not sure on gm..
On the older trucks (07-10) you could lower the min air psi in the module with the proper scan tool. I believe it's possible on 11+ as my uncles 3/4 gas truck is turned down.
Still cannot take the tpms sensors out, however you can run the tires at a lower psi which is what I figure your trying to accomplish
Harbin_22
3,858
7
Southern Indiana
I personally don't see the point in removing them. When I bought my 20's, I got an aftermarket set off eBay for $125 and have worked great. I did go to the dealer and had them lower the pressure setting. They didn't charge me anything to do it
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Why does he want to remove them?
x3.... I love TPMS. One less PITA thing to do/check when Im at the gas station.
t2timmy
2015 LML Denali
Jun 28, 2013
92
I had the dealer lower my setting as well - No Charge. Soooo why couldn't they then just shut off the setting all together?
$chultz38
230
5
Take a piece of pipe weld caps on the ends after putting the tps sensors inside with the stems sticking though and air the "tank" to whatever air psi you need so the lights not on and mount it to the truck some where so the computer thinks you are still using them.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
:nopic:
durallymax
Apr 26, 2008
2,756
Under The Hood
Sounds like a lot of effort for a nice system that doesn't cause issues.
Never had issues with any of our TPMS. I will say they can be pricey. The VW service kit is dumb. I paid more for an o ring and a nut than I did for the sensor itself. Only need them if you are getting another set of rims though.
When I used to work in tires the only issues we ever ran into were improper cores being installed by previous shops and corroding. I worked in the early days of TPMS too where you would expect it to have issues. Other issues stem from improper mounting and dismounting of the tire.
Overall I like pushing a button to check them. The reason they are there is because nobody ever checks their tires. Tires are not cheap. I wish we had TPMS on all of our semis and trailers because those are even more important as they get more miles and tires are $450-600 each. I could put an aftermarket system on but they're too expensive for now.
Sent from my SCH-R970 using Tapatalk
$chultz38
230
5
He asked if it could be done and that's how. Not too hard to do maybe a hour tops including painting...
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
That's funny.. Never thought of that!! It'd work!
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Maybe the same reason you cant have the dealer disable your airbags or ABS.................................?
(TPMS is a FMVSS requirement on all 2008+ MY vehicles under 10,000lbs gvwr)
t2timmy
2015 LML Denali
Jun 28, 2013
92
Ooooo... Good answer! I didn't know they were a required safety feature?
