Does anyone know the weight of the rear half of the truck, I.E, the bed with frame, fuel tank, hitch, bumper? I'm looking at a set of airbags, it has a minimum of 20psi @ 1500lbs to achieve my ride height. So that's 3klbs at 20 psi, I'm not too sure if it would make my rear end too high at that pressure since I do not know the weight of the rear end. The total weight on the rear tires does not count since the axle is not part of the weight, it has to be the upper part of the body. The airbag manufacturer recommends not to go under 20 psi if I'm trying to achieve ride height unloaded, not sure why though.
