Rear axle choice for 1/2 ton
1pieceatatime
179
Schuyler NY
So are guys actually running detroits at the strip with success?
Anything I've ridden in with a Detroit felt like a giant pile of shit on the street, even just leaving a stoplight. They are also axle breakers on the pulling track.
5,818
pull truck is a completely different animal.
if your tires are different sizes or not worn the same, its gunna cause some havoc. detroit is always locked until there is enough force from unequal spinning tire to unlock it. we are not making turns at the strip nor are we loading the truck down with a sled in dirt. yes ive seen detroits used in these trucks, cars and everything else without issue at the strip.
1pieceatatime
179
Schuyler NY
I know how they work, I'm quite familiar with diffs in general, I just have ZERO drag racing experience. I'm curious what everyone has to say as the OP PMed me on another board and asked for my opinion a few days back. But a 9" wasn't part of the equation.
1,866
BTW, do you all have a recommendation for brand of gears? The OEMs looked a bit worn in, and I didnt bother to check backlash when I tore the axle apart to verify.
thunder550
1,176
Phoenix, AZ
I could always go with an Auburn, Grizzly or TruTrac, guys.
TrueTrac in my 10 bolt, has held up fine for the past year, don't even know it's there until I get on it. Getting ready to build the trans, will see how everything holds up to the extra power after.
bcdeutsch731
619
13
41
Illinois
I don't have the time to read all the post, but when I first built my truck I used a Dana 61. It's the same as a Dana 60 but uses a much higher gear. I ran a 2.91 and probably had over a 100 runs on it at the track. I finally broke the pinion lunching at 40psi of boost at the track. I found a 3.00 gear set for it and had it cryo treated and probably have over 100 runs on it with out any problems. Strange Engineering made me a spool and street strip axles. I cut the ends off the rear end and had Ford big bearing ends welded on. That way the axles could never come out if they broke. I still have the rear end in the trailer out back. I dyno'ed 770 rwhp and went 10.6 with this rear end.
The next rear end I used was a AAM 11.5". I found a 3.21 gear set and had it cryo treated. Moser Engineering made me a spool and street strip axles. Just like the Dana 61 I cu off the FF end and had Ford big bearing ends welded on. I never had any problems with that rear end. I dyno'ed 1100 rwhp and went 9.8 with this rear end.
I run a TrueTrac on my DD and love it. I don't hear anything going around corners and 99% of the time it's nice and smooth. Once in a while when it's raining out you can feel it going around a corner but other then that it great.
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
I have a 9.5" SF axle apart in the garage. Has G80, 3.73, disc brakes.
Pros: I have it. Cheap to put together. Fits the spring perches.
Cons: Not too excited about using a SF for the strip. Possible (probable?) durability issues.
I swapped a 6 lug 9.5 14 bolt SF axle into my turbo'd half ton and put a tru trac in it with 4.88 yukons and loved it(truck was a t56 6 speed). Made 535 to the rear wheels and I ran drag radials on the street(ECSB weighing in around ~5300lbs). I was more concerned about driveshafts and my clutch than the rear. I also had a T/A girdle on it too. It was out of and older truck and I had to move my perches out. I was able to retain my disc brakes by rotating the caliber.
1,866
I have no real experience with rear axles, so I thank you all for your input. It is VERY much appreciated.
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
What is in the truck now?
1,866
How's $470 for a brand new Detroit Locker for the 9.5", with outer bearings already installed?? :) Thanks Zak, that was a great link. :thumb:
Main cap studs, TA Performance girdle coming, too. :)
