Rear axle choice for 1/2 ton
1,866
Rear axle choice for the 1/2 ton
Since the 11.5" out of the donor was bent and not usable, I've got to find an axle.
Im hoping to get some advice on the GM 14 bolts, as I do not have much knowledge on them. I've read their Bible, but even that info hasn't helped me figure out which axle would be the best choice.
I have a 9.5" SF axle apart in the garage. Has G80, 3.73, disc brakes.
Pros: I have it. Cheap to put together. Fits the spring perches.
Cons: Not too excited about using a SF for the strip. Possible (probable?) durability issues.
I would much rather use a 10.5" FF axle, but the big question is, which one?
Would one of the older axles ('86-2000) have the same spring perch width as the 1/2 ton in order to bolt right in or do I have to find one from a NBS (99-up) 2500 truck? Trying to stay with the 3.73 gears and disc brakes.
Pros: Cheap. Detroits are dirt cheap, too. Strong. Lots of aftermarket.
Cons: Have to spend extra on Detroit and disc brakes (unless using NBS axle) but what-can-ya-do?
BTW, are the axles out of the 2500 Savana vans compatible with the pickups or are they a different width? I keep seeing 12-bolt versions of the 10.5" and wonder if that would be another possibility, too.
Any advice you can give would be very appreciated.
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
I can tell you from personal experience that the SF 9.5" is very stout. Had one with welded spider gears in my rock crawler with 4.56 gears and 36" tires and never had issues.I don't think the spring perches are the same from 86-00 to 99 and up. Van rear ends from my experience were a tad bit wider iirc.
5,818
Stay with the 9.5" SF, specially if it's 6 lug and your staying 6 lug on the front. Can't remember if you swapped to 8 lug up front or not
5,818
Your light which really helps. If you go 10.5, your gunna have to look at 2001nbs and up trucks to keep disc brake and direct swap under the truck. If your worried, that's what I'd look for
thunder550
1,176
Phoenix, AZ
Tom, I didn't like my 3.73's, it was too much gear for the light weight truck and small tires. I swapped to 3.42's, and may eventually go to 3.23's depending on how the truck feels after building the trans. I know you have different goals for the truck, just wanted to share my experience.
Will you be launching with slicks? Foot brake or trans brake?
1,866
I figure I'm going to run a 12.0-16 or 13.0-16 slick, both of which are over 31" tall.
If I were running the 390/40/17 drag radials (29" tall), then the 3.42s would make better sense.
Foot brake to start. Will have to add line lock kit to truck.
I actually have zero experience with a trans brake.
thunder550
1,176
Phoenix, AZ
:thumb: tire size calculator says my 275/55R20's are 31.9" tall
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I know BIGLEY runs a 6 lug 9.5" rear axle in his 88 DURAMAX swapped truck, and was dyno'ing well north of 600HP(I think it was 648 last vid I saw) through his, as well as running it at the track. If your already 8 lug, then I would look for a 10.5" rear diff myself. The 9.5" will do it, but since you don't have to go with custom hubs why not step up to the 10.5" to begin wth. I think you lose a few gear ratio options with the 10.5" VS 9.5", but yu gain ALOT in strength with the full floating hubs, and 3 bearing pinion support system. Only downside is you don't have as many diff options with the 10.5" rear axle. I wish they would make a TORSEN style for one as the factory G80 in them is pretty weak, and a detroit isn't ideal for DD use.
13,713
775
Have you thought about building a 9" for it? I know it probably isn't the cheapest, but it may be the best.
1,866
So, where would be a good place to get a deal on a 9.5" Detroit? :hehe: No....seriously. Looks like $580 is about the least expensive I've found so far.
I think I'll call Merchant and see if he'd like to trade that 261 Tcase I have for the labor to set this axle up.
1pieceatatime
179
Schuyler NY
You think a 9" is that much stronger than a 9.5? Dollar for dollar built with apples to apples parts that is.
Are guys running detroits on the drag strip? I would think it would be jerky.
13,713
775
I don't think it's any stronger in stock form, but the aftermarket is way better. From what I've seen, there isn't much aftermarket support for 9.5" 14 bolt axles. My biggest problem with the 9.5" in a serious drag racing application is the c-clip semi-float axles.
1pieceatatime
179
Schuyler NY
Hard to compare anything to the 9" in terms of aftermarket.
I'm just thinking the 9.5 is a little oversized for the weight of rig so it should fair well and be less parasitic than a bigger full floater. AND he's already got it.
13,713
775
That's all I was getting at. The Ford 9" has the ability to grow with the truck whereas the 9.5" 14 bolt is pretty much at it's max potential already. The fact that the 9" is probably a lot lighter is another added bonus.
