RDL Up pipes and EGR delete-LBZ
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Got all the wheel liners off, up pipe heat shields, and started truck and "batteries not charging" light came on....WTF...Great..
Postpone another day, dealer tomorrow morning for new power distribution block... See if that fixes it.
Manybe Matt will have his motor in by the time i come back.. :D:rofl:
ripmf666
15,123
14
47
Wentzville Mo
When you hooked that alternator back up there is 2 plugs that are the same, one id for the driver side alternator and it stays down in the valley out of the way.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
This was the little problem that I was having...
Power junction box
Random truck shut off's and my alternator blowing up 3 months ago.
it was grounding itself out and causing a short..
Black part in second picture is where it was making contact.
redws6rocket
406
Odessa, MO
i love rick's up pipes, very easy to install and great fit. we have just removed the cooler from the valve and motor. run a 5/8 heater hose and cut out a simple plate and installed on back of the motor and valve.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
So what are you gonna run this weekend
Your truck has at least one more run in it:rofl:
Are you going to get your truck done in time? Need any help?
Dont know if im going to run. I have a bet with MMLMM and were gunna lay the smack down when he comes her ein July. :D
KEVINL
1,431
Phoenix, AZ
Ha I don't even have all the parts. Maybe If I pull a few all nighters
Seriously though 100+ Degrees and 3000ft are not the optimal conditions
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Did newly hook you up on the studs and gaskets?
Has your garage door been open this whole time? :rofl:
KEVINL
1,431
Phoenix, AZ
He hooked me up on the studs
Yeah the garage is still open truck wont fit It is about 4 inches too long when it is pushed all the way against the wall
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Id like to thank rgullett83 for giving me the idea of getting the egr gasket and then cutting around it. That probably saved me 6 hours of time after everything was apart.
:hug:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Bad news :eek:
Got all manifold to up pipe bolts off, downpipe, exhaust.
got 2 out of 3 bolts off of the drivers side up pipe to pedistal, and bam.. bolt breaks.
Im screwed, put it all back together, and gav up for the time being.
Bolt is broken clean off.
atleast it give me a good reason to take the turbo off and replace it...:(
Bad day. :mad:
Jun 28, 2007
3,259
NE Pa
Bad news :eek:
Bad day. :mad:
Those bolts are aircraft grade. You'll need some good drill bits to get it out.
