Wanted to start a thread for round two of my 99 RCSB/LLY swap truck. The original swap thread is here:
http://www.duramaxdiesels.com/forum/showthread.php?t=47483
I replaced the water pump in mid August since the original one was leaking out of the weep hole. Cheaped out and bought a new Bosch pump from Amazon for $60. Ran fine for two months and spun the impeller, overheated and failed the LML studded head gaskets (I should know better by now). Oil pan was leaking also so I decided to pull the motor strip it down to the short block and re-seal everything, fix the head gaskets, and do the twins that I've been wanting since the wife is being supportive of this ridiculous and expensive habit :woott:
Lost the HGs on a wide open run down a frontage road, trying to do some logging for a surging issue I was having at WOT in 5th gear. Overheating warning went off about 1/4 mile from my house...limped the truck home and found an empty overflow bottle and coolant sprayed all down the passenger side. Drained the coolant and found lots of soot mixed in :
Time to pull the motor
I didn't know initially that the water pump impeller had spun. Didn't see any obvious failure points on the head gaskets:
Everything started to make more sense once I opened up the WP housing and found this:
Lesson to be learned here...don't cheap out on parts! Several people told me to get a pinned or welded pump and I didn't, paying the price for it now.
