We are struggling with the LBZ bouncing severely. Any help or experience would be appreciated, I have only made 2 hooks in my life so rookie would be an understatement.
RCLB 6640lbs with driver
Torsion bars up front, no limiting, Rancho 9000's maxed out on 9
Rear track bars with a small amount of preload, Rancho 9000's on 9, suspension stops about 4-6" above normal ride height
Hitch height at 26" (or whatever the max allowed hitch height is)
305/50R20 Nitto 420 50psi rear 35psi front
We cannot hang weight or add weight, it must remain constant from the start of the event to finish.
The front is lifting to the point of airing out the front tires while hopping. We will be trying a different hitch configuration to bring it closer to the rear axle and reduce the leverage effect when the sled weight moves forward.
Sent from my SM-G965U1 using Tapatalk
