RCD lb7 71
cafryer
May 5, 2011
1,074
Utah
I just bought an 01 with really low oil pressure for 2,500
I agree that lb7s are becoming affordable as a "play" truck
And as far as I know it takes a shit load of hp like 800?? to even be competitive in 2.6 so WS would be much much cheaper IMO
X2 lb7s are still my pick :thumb:
jheyob
305
Okeana OH/West Lafayette IN
I believe Fleece dropped the IHI cheetah because the IHI housing when opened up to the max and with a matching wheel only flowed like 15%? more than stock. Basically a waste of money when it's going to fail tech for a stock turbo class and wont hold a candle to a true 2.5 s3 or s4.
Not sure if that ad had a price or not but I was told $3000 for the 71mm :spit:
cafryer
May 5, 2011
1,074
Utah
Just looked at the top 50 list and atleast 23 of the trucks on the list are lb7 i think they are doing fine.
TQMONSTR
Nov 19, 2009
161
Canada
really? you mean no one is in a hurry to mod the hell out of their new trucks. i bet most of those guys did up an lb7 cause they found one cheap and they didn't want to risk blowing up their daily drivers. i am only guessing though.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
That's fine...but that would be a skewed example.
Think of the year breakdown...LB7s - 3.5 years, LLY - 1.5 years, LBZ - 1.5 years, LMM - 2.5 years, LML - TBD. The LB7 has been out the longest (i.e. more R&D time in the aftermarket)...I'd hope they'd have a fair showing.
I see the turbo discussion has changed since a price was listed.
I'm going back to watching my dvd of SDX '04.
DMAXDOC
May 26, 2011
119
A lot of people cant afford a new truck period... thats why they DD and mod the lb7 they have and can afford
sent from a combine cab
FarmDiesel22
Farmer
Sep 28, 2009
128
There is a thread on diesel place about the 66mm version of this charger. I guess it's a whole new center section. The only thing the same is the cover and exhaust housing. Not sure on price but I bet a s400 would be cheaper. River city puts on a few pulls and the work stock class is a stock appearing class and doesn't matter what size the turbo is. So I imagine that's y they r building them
cafryer
May 5, 2011
1,074
Utah
Cool ihats the info i was looking for.
Fastorange
Jan 31, 2009
256
ohio
lol the d.t.466 is older than an lb7 and people still make them run.... the lb7 is a good runner... yeah they have injectors under valve covers. and they can be a pain to work on.. but they run good.. its all about set up..
Fastorange
Jan 31, 2009
256
ohio
I also think that the reason the IHI turbo hasnt had much R&D is because no ones knows much about them.... I mean you can get all kinda of parts for garret turbos... and garret makes alot of diffrent turbos... so its ganna take a little more work for the ihi... its not ganna be as easy as calling up engineered diesel and make a vvt cheetha
FarmDiesel22
Farmer
Sep 28, 2009
128
Also heard that the truck that has that 66mm charger might have an article in diesel power mag sometime. Not sure if that is true though.
