During our LSR buildup we checked various things out that might keep the engine cooler at sustained high output.
What I found (with the help of Jason - LBZRcks) is our factory thermostats open very slow, and are quite a bit restrictive.
The bypass blocker opens in 20 seconds, and the second one opens in 43 seconds. Neither have very large openings.
So I bought a dozen different models of thermostats, and we tested their performance. We found a set of thermostats that open nearly 3 times faster, and flow about 1/3 more water when they open. They also open 25 deg sooner. Your water temp gauge will read ~175 instead of ~210 (gauge on trucks isn't too good).
Starting line water temp at Bonneville was 158 deg, and at the end of the track, the water never exceeded 180 deg. Dyno testing showed a maximum of 175 deg. A few beta testers have been running these with no issues so far.
If anyone is interested in running these, I'm selling them for $69 a set to help defray the cost of testing. Email [email protected] or call us at 951 270 0808 to order. Leave detailed message when calling if the machine kicks on.
These are intended for racing, especially sled pulling or LSR, to avoid hot spots from forming while awaiting the thermostats to open. Whether they would help an overheater or not, I have no idea, so no fights about overheating please.
