trent how much did they improve your 60's?
Well, my QA1's (along with the Caltracs) helped me go from a best 60' of 1.70 to a best of 1.66 on the Toyos, and my front end didnt jump up as harsh or as far as it used to. We'll see what happens next year with drag radials.
see thats the problem with the decision I have cut 1.64's with just Proxes and clamps. I now have DR's but i've yet to use them on a prepped track
1.64 are great , the hard part is could you do it at any track you go to ? and every pass you make ? If yopu can i wouldnt spend the $$ . That is what the biggest benifit i have seen from the DR and a decent suspension setup is i can pretty we count on 1.64 or better at any track I visit and almost every pass i make , with in reason any way .
My truck end lifts WAY up when I launch and my rear end bounces through out the whole run. I am gonna run the DR's this weekend to see if they even help then go from there..
Has anyone used the single adjustable version?
Tom ( thebac) , Camomax , and NJLLY are running the single adjustables i think .
If the front is lifting, you need less rebound/better shock in front. Clamp front and back of the spring, Mine hopped until I did. 38 front 35 rear with the M&H's is what worked best for me. Less in the front and you will see cuping in the tire. Less then 35 rear, and the truck transfered too much weight to the rear, and the front would spin! Figure the rest out on your own:thumb:
Alstons in Sacramento sells Varishock single adj. for $187, dual adj. for $299.
7,460 with me in it and a little more then 1/4 tank. I only checked it once last year. I probably had it down to around 7,200 when I was in Idaho a few weeks ago. Your truck is a bunch lighter!
