QA1 shocks
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
started a new thread for easier reference . installed my QA1 front shocks last night and so far the part # DTC1538P worked perfectly , leangth was perfect . Only thing that needs to be done is the metal bushing sleeve is to small for our lower shock bolt . I stole the metal sleave from the stock shocks and used it but you can buy a sleave before hand now that we know its needed . you have to enlarge the hole in the poly bushing to fit the larger sleave i used a drill bit . the top mount is a little loose till you tighten the nut on the shaft compressing the bushings and then it is very solid no play .
so far quick drive last night and they are very very nice , but they should be for that price , i ended up for stiff street/performance set up 10 clicks rebound and 5 clicks compression , there are 24 clicks for each setting so there is plenty of adjustment for our trucks . i will keep updating this thread as testing continues. As of this point i can say they seem to be worth every penny :D front end dive under breaking is non exsistant, and cant feel any lift under exceleration but ride is not harsh stiff wich i like but not harsh . i will have them at the strip in 2 weeks :D
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
:cool2: how much did you lower your truck in the front? Would these shocks still work if the front was lowered 5 inches?
TrentNell
Jul 7, 2008
7,543
slc tuah
mine has the tbar bolts all the way removed and still have 2 1/2 - 3" of downward travel, these would be the equivilant to stock leingth. but check they have many different leingths availible .
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Shocks
Thanks Trentnell! I will be doing the same thing shortly. Keep us posted as to how they work. I was going to go with Koni but I think I will go with QA1 also. I like were te knobs are for adjustment. Jeff
TrentNell
Jul 7, 2008
7,543
slc tuah
after driving this around town playing with adjustments and such i think once people get past the sticker shock you will see alot of guys going this route . specialy once a few of us get some track results i think its really going to launch well , and the beauty is that within the settings you have tyhe perfect shock for any occasion no matter if your racing , towing , or just crusing , they are quite impressive the valving spectrom , from very soft to harder than you would ever want , still have not maxed them out . i will though just to find there limmits . so far crusing around town i just change a click or 2 and see what it does .
TrentNell
Jul 7, 2008
7,543
slc tuah
looks pretty good . have not tried the single adjustable but almost did because they were 100 bucks less might be a good . i am shure they are top notch just have to try the valving out and see if you like it . the thing that made me go to the double adjustable's is i tend to like low compression and very heavy rebound settings . , after driving the truck with zero shocks ( like litteraly not even mounted ) i got a good feel for the spring rate of our torsion bars and they have about the right stiffnes with out a shock . i am running 5 clicks on compression and am up to 14 clicks rebound... feels realy good :driving: lets us know if you try them .
TrentNell
Jul 7, 2008
7,543
slc tuah
Might try those along witha 3/5 DJM lowering kit and run 18"
:cool2: , they would work great they still have the rebound adj . wich is what is relly nec , i might try some a-arms or drop keys myself . not shure wich is better though . i only want another 1"-2 " of drop more on the front , scared of the axel angles going to much negative angle , what are your thoughts on this ?
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
i have been trying to compare these to the Bilstein Air-over-shocks that Pat was running...i can get them for the same price so i am pretty torn. what do ya'll think?
TrentNell
Jul 7, 2008
7,543
slc tuah
For racing i would say QA1's hands down ( or any other quality adjustable shock ) , the air over shocks are more of a load helper . what is your use going to be . i asumed racing because of you toyo thread :D
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
correct...racing.... application would be on my 01. if they work well enough then i will probably swap out the 9000x's on Ironhyde too because sometimes we can't run our Road Armor and our front end shoots up off the line
TrentNell
Jul 7, 2008
7,543
slc tuah
i have a few of my sled pulling budy's looking seriously at these after seeing them in person and feeling what kind of adjustment they offer .
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
I just picked up a set of qa1 R series pn#hal-rc15389 they only have adjustable rebound , but that is all I'm interested in. Ill be pulling with them this weekend. they only cost 139.$ so far I'm very impressed with them looks to be a must for drags and pulling.
ripmf666
15,123
14
47
Wentzville Mo
Do you have a link to the site were you found them at ?
TrentNell
Jul 7, 2008
7,543
slc tuah
Sweet thats good price ... let us know what you think ? how much rebound adjust do they have ? was curious if they could go as stiff as the double adjustables ? it would be good to have a cheaper alternative for the guys not wanting the double's .
JMK777
Mar 20, 2008
1,433
5
Moss Beach
Got them through summit racing. They have them in stock. They also make a steel virson
That is even cheeper I think 75$ each. Thev have 12 clicks of adjustment (rebound). I'm going to do a coupple of holeshots tonight after work , ill report back
ripmf666
15,123
14
47
Wentzville Mo
