pump shim
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Did you just buy the altos josh? as far as i remember alto didnt make a kit for the 6spds like they do for the 5 speeds
15,681
Why does SunCoast send a C3 piston with their kits?
And I couldn't get all 14 clutches in my C1. I ended up having to leave 1 out to get the proper clearance.
Suncoast sends a machined piston with Stage four kit. You had to leave a clutch out of the C1 because you were using the Alto power Pak which was designed for the 5 speed. Th aaply plate was the wrong size for your application.
13,735
804
That makes sense. I didn't realize that the 6 speed used a different clutch pack than the 5 speeds. Thanks for clarifying.
bigmackmiller
1,046
Kokomo, IN
mainer just curious as to how much you were in going this route vs. the SC kit i've been curious if it would be much cheaper...feel free to pm' if you don't feel like posting
emkay
DIESELBOYZ member #2
Nov 2, 2006
31
Germany
@ mainer: where did you see the shim/ tool kit on the sunvcoast website or do you have a product code for ordering purposes?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Contact a builder. They usually have a ton of them lying around because they come with the sc kits and sometimes will just give you one.
