the shorter c-3 piston comes in the stage 4 kit , and alows another clutch i beleive .
correct
here is mikes explanation copied and pasted from DP
Suncoast 3 contains 14 Alto C1 one sided clutches with thick apply plate. C2 contains 7 Alto frictions with kolene steels and .200 apply plate, C3 has 5 Alto frictions with kolene steels, and C4 has 6 Alto frictions and kolene steels. Transgo shift kit is included with both filters.
Suncoast 4 has 16 C1 one sided Alto's with custom machined apply and pressure plates. C2 contains 7 Alto frictions and kolene with a wave plate and apply plate. C3 has 6 Alto frictions with kolene steels and .250 apply plate with custom machined apply piston as does C4. A ring gear spacer is supplied to support extra C3 clutch. Transgo shift kit, converter flow valve, and some models get a special C1 dump valve. A pressure regulator spacer is also supplied and both filters.
i think the sc3 may now have a wave plate in the c2 now to slow the c2 coming on in the 3-4 shift where there is the typical "double bang" / tie up that some of the older trannies experienced from increased pressure/ trim valves
anyone feel free to correct me because i only know what i read and try and filter through filth and fact and only retain the later
