pump shim
mainer
Nov 11, 2008
326
i'm going to be building my own transmission.
I already got c1-c4 alto power packs & transgo.
I'll be ordering a suncoast or precision converter in the near future.
I'm looking to do the pump shim mod that comes with all of the major kits.
I was told to use a 135 thousandths thick washer, but the diameter wasnt mentioned. Can anyone give me input here. And also any other advice.
Thank
paint94979
Beer Nazi
Sep 18, 2006
11,715
Thank
give Mike L a call
mainer
Nov 11, 2008
326
this isnt going to be a standard washer by chance is it?
and was I correct with the .135 " thick ??
thanks for the help Mike
15,681
.135 is correct thickness. The spacers are custom made and don't match anything that I'm aware of.
mainer
Nov 11, 2008
326
thanks again for the help.
I'll make a few up this weekend when I get a chance to get into the machine shop at school
mainer
Nov 11, 2008
326
i'll replace my injectors ever 100k vs having crappy oil pressure, overheating, injector harness issues, egr, cat, and those funny looking front ends all lly's have :rofl:
emkay
DIESELBOYZ member #2
Nov 2, 2006
31
Germany
Hey, I have quite the same setup with alto c1-c4 and transgo shiftkit. I also installed the hot rod converter back flow valve from transgo and a 1057 as well as a deep pan. My question is where do you shim the pump and for what reason :confused:
15,681
The shim is installed at the top of the pressure regulator spring to increase main line pressure from 245 psi to a more desirable 275 psi. Much better holding power for the clutches.
Bluemax
Sep 25, 2006
846
Missouri
:exactly: Except so far I'm over 150k on originals....:D
mainer
Nov 11, 2008
326
ok so my complete tranny plans are as follows.... any recomendations would be greatly appreciated
c1-c4 power packs , running just 6 clutches in the c2 (space the rest with stock steels)
transgo shift kit
pump shim to up line pressure from 245 to 275psi
and either a precision or suncoast converter. (purple isnt my color)
