you need more videos of that 80's gm with the duramax in itI pulled workstock here once during the fall with no weights, or blocks I did use traction bars and I clamped the front of the leaf springs and I hooked fine. and you will have to overlook the minor delay at about the 50ft mark I put on a new fuel filter and I think I had a little air in the fuel lines
http://www.youtube.com/watch?v=x2fQ_cf42dc
try them mud tires you said you had,looks like you have some really sandy tracks.
hope this helps :thumb:
on edit;
if you do run them mud tires run higher air press in them,because it will let them spin,not bite as hard!!
So if i run low pressure in the mud tires they will grip to much?
seems to be alot of bfg at's. i was thinkin when i start to get a bit more serious get a set of interco trxus sts'. thoughts??
I think the sts's are a more popular pulling tire, Good luck finding a set, I have been on the hunt for damn near a year now and have spoke with the factory and as of right now they are not being made due to the economy I was told.
If the track is tight, and you have a lot of tire, it bogs hard on the shifts. This can often be combated by moving your shift points way the heck up and staying out of T/H mode.
its all in the set up i pulled against guys with a5k's and built this and built that made 100-150 more hp more than me...i regularly handed them their behindsI always seem to find myself getting smoked buy trucks with 75-100hp less then mine.
