project " shoe string budget"
kenp313
Feb 14, 2016
92
Today I installed my front cover and TRIED to install my front main seal.can you say FUBAR :booboo:? How hard is it to remove the front main with out removing the cover. Also, is there anyone willing to RENT me their seal driver?
1,971
Do I want to know how you tried to install it? Sorry you've got to spend more money. That shoestring is getting kinda frayed.....
kenp313
Feb 14, 2016
92
I had a brilliant idea to install it and it turned out to be one of my more ignorant ideas. That seal seemed easy to install but it looks like I beat it on with a rock
Sent from my SAMSUNG-SM-N910A using Tapatalk
kenp313
Feb 14, 2016
92
Is there a way to install it with out the install tool
kenp313
Feb 14, 2016
92
Progress report: i bit the bullet and ordered the seal driver tool set from merchant. (Ouch). On a positive note i would like to say thanks to hipp11b for hooking me up with a great looking rear engine cover. $0.00 is one hell of a price. Yesterday i was able to install lifters and head on p/s. That 125 lb/ft on those studs gets tiring lol. TODAY i was able to install turbo,clean the injector cups (12ga bore mop and a drill), cp3, and y bridge....PS: F#$@ you y- bridge, you are a pain in my a$$. Dont know why its was so hard to install. Oh and i also had the privledge of pulling the front cover off and throwing away a $30 seal.
Sent from my SAMSUNG-SM-G928A using Tapatalk
kenp313
Feb 14, 2016
92
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Did you pull the cups from the heads and reseal them??
If not please do so now..
kenp313
Feb 14, 2016
92
There torque lock cups from industrial.(threaded and red locktite) No need to i believe ?
kenp313
Feb 14, 2016
92
Pogress this weekend. Got driver side injectors installed, rockers and lash set, valve covers, fuel lines, PPE rail fittings ,and engine mounts. Also pinned my balancer with rhe EMPIRE CRANK PIN KIT. (Awsome and easy to use tool).
More to come today if i feel like getting off of my ass. Special thanks again to HIPP11B for rail fitting and engine mounts.
hipp11B
Apr 1, 2015
252
Georgia
As always brotha you are most certainly welcome! Let me know when your ready to drop it in and we will get a plan in order of you wanna do it at the craft shop
Lbz, built trans, efi by Danville, Danville 68, full egr delete, mbrp down pipe, 5" mbrp to 7" stack, ppe guages, custom traction bars, airdog2 165, ppe fuel rail mods, s&b, afe blade runner, Arp head studs..died March 2015
Parts collected for the build. SoCal super damper, SoCal billet flex plate, SDP S400 kit, II 85% CP3, PPE manifolds/up pipes, PCV reroute. Slowly but surely lol
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Know it's already been covered. But I've bolted a hg to check valve clearance etc then pulled it off and reused. I didn't use the copper spray on the mls. No issues, running truck very hard. but do on other gasket materials
kenp313
Feb 14, 2016
92
Been discussing it with the wife, we're gonna Finnish engine here and see if Brad will pick it up for you and I to Finnish dropping it in
