Project race truck
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
In class I can drive with that, compounds would probably be allowed. Class is called Super Pro ET, an it is index class with 7.0-11.99 second times.
I believe this is not competitive combination against naturally aspirated fuel cars that can drive their indexes very close, but at least I can get some official race passes with this and drive my own records.
If all goes well, maybe later we can get some rule changes so I can go to drive other, non index classes.
I want to try traditional twins because I believe I can get more air and enough boost with less egt and drive pressure, if I ever can spool those turbos with nitrous :roflmao:
I had serious heat problems with heads last summer and have to try something else now.
boss760
Mar 8, 2010
72
Clarkrange, TN
I like your truck. I need to build something for next year. I've got a good motor, but my truck is not set up for racing or pulling. We are putting twins on it hoping to go to the DPC. When we get done I need to build a drag truck. Would like to do a 57 Chevy.
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
Some update with not much new, been busy at work and building one turbo bike, and waiting parts to come.
But now I have windows, seat, belts, dry sump pump and nitrous kit home.
Transmission is coming soon, I will stay for now in Duraflite because it worked so well last year. But now it come with Omega shaft and stubby housing.
Still waiting chutes and fire system, and looking for air shut off system.
I am little late on schedule and still working with fibers, but truck will go to our biggest car show in april so then it must at least be painted and look like something. Hope to get it running some test runs next summer.
custom8726
2,784
Upstate N.Y
Looking good man :thumb: From a aesthetics point of view I believe the front wheel wells should be molded to fit the tire better IMO.. Not that its going to make it any faster but just more streamline.. Regardless awesome build :)
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
In nature wheel wells looks good. They will need some strengthening and aerodynamic modifications. But position of wheel with fender is ok.
Problem with pics are that my garage is so small that I cant get pics of complete truck side, and because we have 1 meter snow I cant take it out of garage for pics.
custom8726
2,784
Upstate N.Y
Makes sense, looking forward to seeing it finished in paint...
Ryan T
1,007
CA
that is buy far the baddest, most unique drag machine ive seen, good job, this sport needs people like mika:coolspot: sick, sick ,sick...
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
Well maybe not so baddest, but chassis is made with pro mod specs and buildt to fit full size silverado body. So unique it is, and driver (me) will sit almost half meter higher than all other competitors :roflmao:
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Looks great Mika, question..Is an airshut off system required with a common rail diesel in Finland? Someone correct me if I'm wrong but I don't believe that is required here?
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
It is in most pulling organizations, a common rail can run away also
Mika
Bastardo Finlandias
Oct 25, 2008
291
Finland
Well, it is now required here:roflmao:
I had meeting last autumn with our national drag race association for some rule changes so I could drive this vehicle. Here is few rule changes I got in SPET that comes in my mind now. I had to suggest some safety elements too, and air shut off was one of them.
-In old rules only n/a aspirated diesel was allowed, now charged diesel ok.(Some weird old bug)
-Diesel may use nitrous in burnout too, and dont need 100% throttle switch
-manual throttle plate not necessary in diesel, but instead of it wire launched air shut off, pedals in cabin and outside, 11.99 and faster
-must use stacks in all 11.99 and faster (competitors were afraid of smoking clocks)
05greendmax
dyno and drag numberssoon
Dec 26, 2009
435
ohio
wow man i love seein custom fab work congrats on the build this far u still have a long way to go but im sure it wil fly more pics if at all possible im jelious onece again congrats
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
If a turbo explodes or something else dumps oil into the intake stream, a common-rail can run away just the same as any other diesel, as Rob said.
