i have put a tune on this truck once and it worked fine when i went to change the tune it left the truck stock i have tried multiple attempts and it turns out the same outcome. is this a common problem or am i just and idiot any ideas
reading that gave me a headache lol, j/ki have put a tune on this truck once and it worked fine when i went to change the tune it left the truck stock i have tried multiple attempts and it turns out the same outcome. is this a common problem or am i just and idiot any ideas
the stock tune wont go back in unless you flash it in.......if you had a modified tune in, and tried to flash another modified tune it would be impossible for the stock tune to surface.
this may sound stupid but are you reading the truck instead of writing to it?
(meaning using the green button instead of the red ones)
if you successfully flash a modified tune over the stock tune, there is no way to go back to stock unless you specifically flash the stock tune back in.
well thanks to guy from so cal diesel and some of my stupid mistakes its all fixed
