PRND321 underline issue
2,264
It's a GM part. Where is the other end of the plug located? Does it go straight to TCM? Does someone have a schematic or can point me in the direction? Hard to meter wiring without knowing what's what.
Thank you for the continued suggestions, guys
Sent from my SM-N976V using Tapatalk
13,744
817
Here is a little more info on the operation of the NSBU switch:
NSBU Switch Range Chart
RangeABCP
POFFONONOFF
ROFFOFFONON
NONOFFONOFF
DONOFFOFFON
3OFFOFFOFFOFF
2OFFONOFFON
1ONONOFFOFF
Reactions: 2004LB7
ieetgluu
Sep 27, 2013
29
RangeABCP
POFFONONOFF
ROFFOFFONON
NONOFFONOFF
DONOFFOFFON
3OFFOFFOFFOFF
2OFFONOFFON
1ONONOFFOFF
It's looks like that's the pinout for 01-04(2 plug) , which is awesome, but I need 04.5-05(single plug). Is the tcm plug pinout also different between the two?
Thank you
ieetgluu
Sep 27, 2013
29
If the TCM C2 pinout is the same 01-05 then I can use that with the LLY Engine Controls schem. that 2004LB7 posted.
All good stuff, guys, Thanks
ieetgluu
Sep 27, 2013
29
At first I thought this was gibberish lol, then I looked harder and separated it out
Given that D321 are all messed up, I'm guessing the issue will be on "C"
13,744
817
Sorry, for some reason I thought you were working on an LB7. Maybe when you mentioned your early TCM, it got me mixed up. Here's a pinout for the newer style LLY NSBU.
  • LLY nsbu connector pinout.pdf
ieetgluu
Sep 27, 2013
29
Download fails each time I tap on the pdf . I'm guessing tapatalk issue
ieetgluu
Sep 27, 2013
29
Troubleshooting nsbu wiring end to end was on my list of things to do this weekend. However, I hopped in it yesterday and the dam thing is back to normal. Was good again today, for now. It's been getting cold overnight here in New England lately but getting into the 70s this weekend. Can't imagine that having much of an affect.
