How much pressure to hold GMAX single sided frictions at 700 HP?
The single sided clutches are only ok in the c1 right?
How did you get to 270 psi? And yes bump the pressure up.Pulling transmission for converter swap. Should I upgrade to suncoast specd gpz clutches and bump up pressure? Truck is used for sled pulling and is at 270 psi.
My spring will put you at 290 psi, add a shim and you're at 315-320. Add 2 shims and you're at 335-350.
Trans has stock spring and suncoast shim. What should my pressure be? With 700 hp in a sled pulling application.
You are running 255psi. Not enough.
Where do you tie into line to test? I'd like to test mine
Pressure plug is at the bottom of the bell housing next to spin on. You will need a special adapter.
700hp in a sled pulling application, I'd put in mikes spring and install the shim as well for right around 325 psi. What clutches and converter are currently in the trans?
Benefit a stock trany ? Not really looking to bump HP yet
Mike, would your spring and 1 shim be enough?
