ppe wont sell just one piston. We cracked one of theres this summer and the answer we got was "sorry about your luck, just buy a new set"
Just curious John. Not trying to argue. But say a injector sticks open on opposite side his egt probe is would you still see a spike in the egts? Did not know if the heat would transfer at all. A honest question.
Diesels are not meant to floor it and run it for miles at wot.
Yes they are.... trucking Industry does it every day
When you turn output up..cooling has to be increased as well..
I don't run my tractor at WOT to yank around 80k of crane counterweight...
I think it is more about the fuel to air ratio. Higher fuel to air will produce higher exhaust temps
To a point yes. You will actually get to a point where you begin to cool EGTs back off once you inject enough fuel. It happens near or slightly above the fueling point that makes peak power. Go to strong with Fuel and you will actually put the fire out.
