Ppe lift pump are they good
Cant beat the price and have had good luck with them and know a ton of guys running them:thumb: And yes to part B of your quesiton, the best way for most setups is to not even have it running all the time only when you hit say 7psi
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
PPE pumps are a hit or miss it seems. Ive had my TTS pumps on for over 2 years without a single issue. Quiet too. :thumb:
the pump is "flow through" but you wont be going 65mph on the freeway if it takes a crap. Maybe mor elike 25mph.
Righteyeblind
712
Fairbanks, AK
I have an edelbrock 1792, same thing pretty much and it is good I replace one every 2 yrs but I only turn it on when I'm getting on it. I can run 70 down the highway without it on.
maxaholic
1,876
40
Central, Texas
Mine crapped out after 10k miles as did my buddies. I'm not knocking PPE but that pump is junk. Although PPE did stand behind my buddies and replaced it no questions asked. I would go with an airdog or fass.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Mines been on for about 30k miles, run for probably 5k of of those. It still makes pressure (how much I don't know) but it sounds horrible.
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
i bought a 2 yea old used one for 100 bucks,,, lasted me almost a year then it crapped out. bought a brand new one for 250 and its been good for 5-6 months. when/if it craps out ill just send the old one back to be refurbished for $125
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
Like Brian said its not a flow through unless they changed the design. Mine went bad after 6 months and it made my truck go into limp mode. I dont see how you can drive around with it off and still maintain rail pressure? Plus that has to be hard on the CP3!
Sent from my DROIDX using Tapatalk
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
some flow through better then others.. my old one wouldn't let me go over 35. but but in jakes truck we floored it to 70 before we even noticed it was off
Well my buddy has been doing it for about 60k no problems yet it only turns on when he is at 7-9psi and up
whitetrash21
Apr 29, 2008
4,929
Vegas
You leave the pump off most of the time when driving? I was going to run it all the time to help out the cp3.
Mindset goes both ways. Leaving it on helps the cp3, turning it off supposedly saves wear and tear on the liftpump..... whole lot of good that did me.
Chevmeister
Big Dooley
Dec 3, 2010
281
Garnet Valley, Pa
Would it make sense to install a valve bypassing the lift pump? Maybe an electronic valve that alternates with the lift pump, pump has power or valve does. That way at least your not stranded. I'm going to plumb in a bypass valve ICE.
whitetrash21
Apr 29, 2008
4,929
Vegas
Mine has a bypass. I added it so I could run without having the pump on and not have to worry about the pump being flow through.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I've lost count on how many I had. On the flow thru argument, you really can't tell to be honest with you. Some you couldn't get past 2000 rpm because they didnt allow much fuel to flow, others you wouldn't be able to tell it would pass all the fuel you need when it died. V3 is there newest and suppose to fix some issues they had. I had one of those break within in a week IIRC but the one I have now seems strong still
Colt
Jul 23, 2010
523
A set of used Kennedy's and parts just flashed up in garage sale same money almost better parts. K's run and run.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
well i noticed my pump was always fluctuating (making different sounds). i thought it was just the pump being weird as i never suffered from any lack of fuel. but then a couple weeks ago i was like" wheres the loud annoying buzzing sound" (i run my pump all the time) and i thought that the pump had taken a dump...it threw the 0087 code. so initially i was pissed since ive only had the pump for 11 months. but it turned out to be my batteries going bad AGAIN ... i put 2 new red tops and the pump is louder than ever and no more changes in tone, just one consistent annoying buzz:D
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I think the PPE pumps are junk. Ive installed several, and they all seem to fail in about 10-20,000 miles.
Vasbinder
282
Floresville, Texas
How bad is the noise. I drive with the radio off and the windows up and the air blowing. Can the noise be heard in the cab while driving or only when stopped at a light.
