Question: ppe Cp3 pump inlet fitting
rdohara
Jun 17, 2009
122
But it will not work with your stock 5/16 line you need to make your lines 3/8 for it to work
rdohara
Jun 17, 2009
122
this is what i used you can go -6 (3/8) or -8(1/2) and it was $25 for 2 fittings
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
I need one that makes a 90 instead of coming straight out, Dan!!! Im guessing that's not a standard thread pitch?
If it were a 90 you probably wouldn't have room to spin it. It would more than likely have to be something that could swivel, like the AN piece above.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
You could always go with a banjo fitting.
OT
I had a lot of trouble finding metric banjo fittings
I tried using some for the return fuel on the heads with no luck
the holes just seem to big and wouldn't quite seal
Do you have a link of se hat you think might work Josh?
As far as using that piece I wouldn't think twice about using a mm X AN with a swivel 90*
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
You can view the thread I started on them here:
http://www.duramaxdiesels.com/forum/showthread.php?t=19490
Its a nice piece, and at only $36 I think its worth it for the piece of mind if nothing else.... every little bit is something IMO!
http://www.sikdmax.com/catalog/inde..._id=51&zenid=c669f0c965a72535f94941cc4748ba01
Is the ID of the threaded end bigger than the stock piece? Thinking about this piece myself once the truck stays running. lol
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
I was going to come out of the filter with 3/8 hose straight to the pump and just plug the line just above the injector return line. This would send the fuel from injectors back to the tank right?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
you are by passing the FICM then ? the factory routing if i remember right goes from the filter to the FICM , out of the FICM then to the pump , I am not running any fluid through my FICM but it might be a good idea to on a D/D or you lve in a warm climate .
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
The way im seeing it, the fuel passes through the ficm first then to the filter then out to the IP. This according to the arrows on the filter housing.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Yes that Is correct there is a small juntion block also
I'm not sure what you are planning to block off though.
13,765
834
