I really like the 6.7 ford heads. Talked to wade the other day and I might get a cam reground to use the intakes for exhaust and exhaust as an intake.
The exhaust is straight in and we could put larger valves in.
Maybe look into heat treating the intake side of the head.
Using reverse flow would be a little more tricky with these heads, for one your induction route that is currently use is too long and awkward and areas are too thin IMO to handle the flowing gases with temperatures we see throughout the runner's length to drive the turbo efficiently, you want short and to the point exhuast evacuation. Quicker it is removed, less we have a concern of about heat soaking the engine.
I haven't seen the 6.7 Scorpion heads before so I can not say. Thank you for the rod length.
Lt wrote
you may have just F'd those heads up pretty good there with removing the divider between the ports.
Was thinking of doing the same to heads I just finished and while talking to the guys that were helping me along we had a lengthy discussion about this. Apparently back in the late '70's early '80's he had done some work on quite a few sets of twin cam heads with the oversight of Detroit engineers and they did all kinds of port combinations on flow benches and the on the engines themselves. The combo port of 2 separate cylinders; like what is represented in a D-max head actually LOST FLOW and TORQUE when on the flow bench and once installed on the engine. They way it was explained to me is that the air hits the bottom "wall" and the tries to bounce back up the port. Once the valve for the opposite cylinder starts to open, it is trying to pull the air from the adjacent port/valve area at a not so nice flow angle which causes A LOT of turbulence and starts to choke down the overall flow.
once the divider wall was re-installed, even at just a thickness of 0.030", the flow numbers came back up as did the torque numbers. so by having that wall in between the ports is needed to keep things balanced.
we talked for quite a while about how that if these 2 SEPARATE ports were for the SAME cylinder, then removing the divider wall up to about 1/2 the valve diameter in length above the top most curve of the valve seat, is DEFINITELY BENEFICIAL!!
in our case thou, the 2 SEPARATE ports are for 2 SEPARATE cylinders and the pulse flow into each cylinder hurts the adjacent cylinder when they are that close together
What are these twin cam heads and does their configuration come close to the Duramax setup?
If we talk about wave tuning, removal of the wall does kill a tuned harmonic wave. As far as the turbulence due to an obtuse angled corner, you can't bluff what a flowbench shows you. However, was there any discussion on the vortex coverage? Interesting posts! Not to negelect, we can always add material when needed. For now its just modeling clay to find the area contour.
Firing order
1 – 2 – 7 – 8 – 4 – 5 – 6 – 3
Passenger side
1,3,5,7
Driver side
2,4,6,8
While cyl. 1 is open, we have cyl 3 right next to it, 3 doesn't fire until the last, or directly before. Cyl 2 is open, we have cylinder four next on the DS bank to fire at which is 3 sequences away from this point which the charge will be replaced by then for cyl 4 opening point. Cyl. 7 is open, we have cyl. 5 next to it which also doesn't fire until 3 sequences after. Cyl. 8 we have next to cyl. 6 which doesn't fire until 3 sequences as well. Cyl. 4 is open now with cyl. 2 next to it which has already fired. Cyl. 5 is open, cyl. 7 has already fired but cyl. 3 hasn't so both cylinders next to have full runners. Cyl 6 is open with cyl. 4 has been closed for 2 sequnces now. Last cyl 3 is now open with cylinders 1 and 5 on either side, cyl 5 already has fired, however cylinder number 1 is going to need to fire. With that dog-leg the charge may be less dense in that runner and not fill soon enough.
Again thought like Lt mentions the turbulence generation due to extreme angle coming from the straight runner, but, the remainging area finishing that dog-leg is still there. Granted we know forced induction only amplifies or vortex areas. The long straight runner will experience some turbulence due to the sharp change coming from the dog-leg, I hope to shape, and yes add some, but not much material to produce a contour better than what is. Hopefully minimize the occurrance.
Great thoughts rolling around for sure.
Dave, I would like to see NGM's view after since you mention 'would' in what you heard from them. You say the velocity fell off, that only reinforces my belief on the importance of flow rate even in forced induction engines. However, flowbenches they only tell us CFM and unless you have other tools to view flow rates listening to the bench in terms of more if better in CFM alone is a misleading viewpoint from what I have learned. Are we after CFM or are we after OVERALL WEIGHT. My view is overall weight of air ingested.
I will be making some radius gauges of card board using one of my drawing stencils to help shape areas and use a stick than can fasten to these pieces. Well, back to thinking on what you guys have presented, interesting things around!
:thumb: Happy New Year
