Physics Question
When is the bullet accelerating
  • As it shoots upward
    Votes: 6 8.1%
  • As it falls downward
    Votes: 20 27.0%
  • Always
    Votes: 37 50.0%
  • Never
    Votes: 11 14.9%
  • Total voters
    74
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Please tell me that schools are really teaching that the force of gravity is 32 ft/s/s and you made the conversion yourself..... :eek:
Now what if the bullet was fired on a conveyor belt....;)
Taught in metric when I was in school
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Then why was the word de accelerate invented? The bullet will accelerate about a hundred yards from the barrel then de accelerate, which means slow down. It no longer accelerates.
its actually decelerate and it is a type of acceleration, just in the form of slowing down rather than speeding up. acceleration encompasses all changes in velocity + or -
jlawles2
1,067
Danbury, TX
Back when I was in Physics in college. There was a question posed on a test that asked the following:
How do the accelerator, the brake pedal, and the steering wheel cause changes in velocity?
The first assumption is that letting off the accelerator does not cause the vehicle to loose speed.
The accelerator is obvious as it cause positive change in velocity. Acceleration
The brake pedal causes negative change in velocity. Deceleration
The steering wheel causes positive change in velocity in one direction and negative change in velocity in another. Hence it causes acceleration in one direction and deceleration in the other.
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
Wrong. If that were true the bullet would float in mid air
It does. The bullet is going neither up or down. The time is measurable.
The answer Always is incorrect.
Going up, going down it is accelerating. Once it hits the ground: zero, zip, nada.
So the answer is: Only while it is motion.
Definition for always: constantly: without variation or change, in every case. This is not the case once it hits the ground.
15,681
233
Then the word acceleration is a misnomer and realy means movement of any kind as you explane it. When you attend driving school and are told to deaccelerate it means nothing? It means slow down as you enter an apex.
I understand acceleration as a positive forward motion. When that motion starts to slow down, IMHO it is not acceleration any more and I don't care what your teachers told you.
I totaly understand the physics of the question and what you guys are trying to state, but in real life it is wrong as far as the way you use the word accelerate.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Lol ok whatever you say. The bullet would float in mid air if it wasn't accelerating. I'm sorry but you are wrong. Obviously when the bullet hits the ground the problem is over lol.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Mike, you are right for most real world conversations you would say deceleration. But in the physics classroom, and a few other places, you need to say acceleration.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
If bullet has no acceleration it will float in mid air. The bullet doesn't float, it reverses.
Never argue with gravity, it always wins.
15,681
233
What causes acceleration? Energy. When the energy ceases, motion eventualy comes to a hault, and you can call it gravity or anything you want but it is not acceleration anymore. Anything falling to the ground no matter what weight will hit the ground at the same time because of gravity.
What I think some of you guys are not getting is the way we use the word and the scientific understanding of the word as compared to real life use.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Here is an example.
You hold a pen in your hand 6 feet off the ground. When you let go it falls to the ground.
If the pen has no acceleration, it will hover in mid air and never fall back to the ground.
13,751
821
Another way to look at it is you can look at the moment the velocity is at zero. If you look even the smallest fraction of a second either side of zero velocity, the velocity is not at zero.
15,681
233
Wrong.
The bullet cannot float in air because it is heavier than air. So it stops for a short period and falls to the gound at the speed of gravity from which it cannot accelerate. And it will fall to the ground slower from this point than the speed that got it there. So how do we define the word accelerate if the bullet got to a point faster and dropped slower? Don't we need another word for this?
keith2500hd
MOTORKILLER
Jul 20, 2008
57
Burlington,iowa
mike l. you just got to realize its in a classroom environment and ignore reality. that is why some engineers can't figure out why their junk blows up outside of the computer simulation and classroom environment. and the bullet would never stop unless you could stop spinning of the earth, so it will arch over, following the curve, up and over.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Wrong.
Mike, gravity is acceleration. 9.81m/sec/sec. That means for every se nod of free fall an object will increase it velocity by 9.81.
With no gravity a bullet can float in air.
15,681
233
How did we get to velocity? Acceleration? At the point of return when velocity stopped, the bullet falls, do we still call this acceleration when in fact the governing force is totaly different. Energy caused the climb to velocity and when energy stopped, gravity pulled it down at a controlled force. The bullet did not accelerate to the ground.
13,751
821
Wrong.
Gravity doesn't have a speed. There is an acceleration due to gravity which is why the bullet is always accelerating. If you define your coordinate system so that down is positive, the acceleration is positive and there is no deceleration.
13,751
821
Because acceleration is change in velocity divided by change in time. As soon as the bullet leaves the barrel of the gun the force of gravity acts on it, and it experiences acceleration towards the ground.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
It's a very elementary question. The bullet doesn't know the earth is rotating. Earths rotation has no impact in this problem.
Ignore reality? Nah, the acceleration of gravity is the only thing keeping you in your seat.
