P0335
CarolinaHD
969
NC
This is from the gm service manual and it may or may not help. Have you physically checked the reluctor wheel? I remember reading somewhere that just a small nick on a tooth on the wheel prevented the truck from starting.
03Duramax86
Jan 11, 2012
Cape Coral, Florida
Yeah we checked the reluctor wheel and it looked good and was not loose at all. I will re check tonight when I get home. I'll look over what you just posted and see what I can find. Thank you.
3,728
297
If a Tech 2 doesn't show cranking RPM, there are only a couple problems that can cause that.
  1. Bad ECM (this is not common, but if a friend has an ECU you can swap with to test, why not?)
  2. Damaged/loose crank or cam reluctor (or a broken crankshaft)
  3. Bad sensor or wiring harness problems
I attached the service procedures for the 2 DTCs you have set. I'd run through those and see if they get the issue fixed.
  • P0335.pdf
  • P0370 or P0374.pdf
mdemaree227
Oct 29, 2023
12
FF43Ems112103@
Ok I started with my Ecm and they said it was none repairable and sent back the old one. Truck wouldn’t crank at all till I got a refurbished ecm and it will crank now but having almost the exact same issues 03duramax86 was having with his truck
mdemaree227
Oct 29, 2023
12
FF43Ems112103@
Edu fuse was good and swapped relay. So I guess back to rechecking wires and connections or I may still send ficm off to get checked since Ecm was bad.
Just to confirm tho on my crank sensor when I tap into the wires with my paneer prob I get 11.8v on blue/white 12v on green and ground on yellow/black. If I un plug the crank sensor I loose 11.8 on blue/white tho
