So i noticed the other day, my blend door for the recirc/outside air doesnt like to stay on recirculate. If i start the truck with the system already on recirc and a/c, you will hear air being drawn in under the dash like it should be. as soon as i start driving it will close back up and switch to outside air. Buttons on the hvac controller still show recirc and a/c pressed on. if i come to a stop, turn a/c off and hit outside air, the turn a/c back on and the recirc back on, it will work till i start moving again. if i try it with the truck moving, it stays on recirc for 5 sec then switches back.
anyone heard of this? its not a stripped blend door as it will move when commanded and hold the door there (ive tried pusing it back with a screwdriver and its pretty solid). So all i can figure is its either the hvac controller (where all the knobs and switches are), bad wire or blend door actuator. Im pretty sure all these blend doors are actuated electroniclly and not off vacuum but acts like its lost vacuum if that makes sense.
