Ounces vs LBS
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Here's what I removed off the single cab. Sorry, I don't have any weights wrote down, it was too heavy to keep in the truck :roflmao:
Starting from the front of the truck.
removed stock bumper for SS bumper shell and made mounts from stock bumper.
Removed tow hooks.
Removed battery and cables and tray for passenger side
Removed sway bar and end links.
Removed AC/Heat and heater core assembly. (includes compressor, condenser and dryer)
Removed steering column metal dash shield (6lbs)
Removed torsion bar assembly (97lbs total, net weight drop 77lbs)
Removed stock trans crossmember for socal crossmember.
Removed regular cab crossmember behind torsion crossmember (12lbs)
Removed all but 2 leafs in rear end, installed drop shackles and 7* pinion shims.
Removed stock fuel tank for 20gal race cell in bed.
Removed all heat shields under bed and cab by exhaust
Removed rear bumper and installed roll pan
Removed hitch assembly.
removed spare tire and jack and crank assembly.
cut the spare tire crossmember on frame rails.
Removed ALL interior except for gutted dash.
Installed race seat and custom mounts with 5 point
Removed radio and speakers.
Removed everything HVAC related.
Removed door panels, rubber floor and insulation
Removed both airbags and harness'
Removed trailer brake 7 way harness from driver floor to bumper.
Removed washer fluid tank
removed windshield washer blades and frame and motor behind cowl.
I think that's it.
:roflmao:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Nope. Must remove the dash. I used the roll bar to hold the dash up on the sides and used straps around the back bar to hold it up. Worked perfect. The dash pad does come off but no way around it. Pulling the dahs isn't actually that bad, it's the steering column that scared me. Oh, and everything HVAC related was 50lbs.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Official track weights for the LB7 all gutted and shit.
Race setup with me in it and 15 gal fuel.
and front axle only.
:woott:
jacobdewey
This won't last long...
Jan 14, 2011
972
I see a very low 10 or possibly high 9 in your future. My guess is 10.15 @ 135mph
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Well, not the time that I wanted to end up with last night, but night cut short due to me picking up a screw in the RR tire :(
Coilovers did very well, front end didn't raise a bit, junk prep and lots of spills, gained MPH though, trans is doing awesome. Track calculators put the truck right at 900rwhp last night.
wrcknkrw
447
roy ut
Video didn't work for me. Were you running your slicks? I would have thought with slicks you would have gotten a better 60' even with crap prep. Regardless it's a fast pass. :thumb:
5,933
It would spin. I had him relax the suspension some get it to grab more off the line and still would spin. They didn't give a shit about prep last night. Glad I didn't decide to run my shit
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Last bit of weight I could find in the LB7.
Pulled the bed off and removed the outer skins. come in at 36lbs each side for a long bed. Plan on making a bed cage to hold the skins up like others have done. Not sure how much the bed itself weighed, wouldn't be surprise if the long beds are 350lbs+.
I will make 5000 lb race weight next time the truck sees a scale.
CaptPhil
1,012
Delaware
You dont really need 8 lugs per tire, you should remove 4 from each tire. Drop in unsprung weight is where its at. Probably save 5 lbs!
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Weighed my full weight reg cab zf-6 the other day.. 6460 with me in it. I'm 200#. 20" wheels 10 ply tires, half tank fuel and all my normal crap I carry around. So I guess the zf is pretty close on weight to the Allison's
It's lighter. I think it's like 240 lbs, but add a dual disc bumps it up a touch. That truck was 6600 with mud tires and bed of shit when I weighed it
