So I just ordered new wheels (finally) and I was curious if there was preference for new TPMS. Mine are wonky so I am just going to get new ones. Any personal favorites?
My favorite is none. I bought some off a member and never even ****ed with getting them programmed, that way I have one warning and not 5.
Yeah only 2 of mine work now, but having orange on the dash kills me inside a little.
I have only had good luck with oem sensors.
Yes. Deal with them almost 6 days a week at workAs in the AC Delco ones?
Sent from my XT1585 using Tapatalk
I'll keep this in mind, I'm gonna talk to Discount to see if they will throw me a bone on them since I bought tires through them. Do you have a part number on those sensors?
What kind of tires are you going with? If they are not able to hold the factory recommended PSI then you are going to have to also pay to get them reprogrammed to a lower PSI rating. Long story short your light will still be on whether you have them in their or not depending on the PSI in your tire without redoing the programming. If that at all made since...
What is the factory range? 50-80psi?
I reset mine with a Snap On Solus. Fronts are 40 psi and rears are 36 psi
Well I ordered 420s so max is ~ 55 psi IIRC. Ill just take it in and have them adjust the range.
