ok.. So crank for a few seconds with no signs of life
13,752
822
What color are the wires going to the plug on the MAP sensor? It looks like gray/black, white/black, and orange/black. If it is, that is the plug for the baro sensor. The MAP sensor should be gray, light green, and orange/black, which is what it looks like are in the other plug Ben says is for the MAP.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Then wtf is the baro sensor cause it's not where they show it in the pic and there aren't any other plugs that fit the map sensor.
13,752
822
The baro sensor is mounted on the bottom of the bracket that the bale connectors mount to. There should be a short pigtail connector that goes between that plug and the sensor (similar to what the FPR has).
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
OK so i'm convinced that this truck doesn't have a baro sensor, this is a special go fast edition and didn't come with it. I'm gonna go up to Fleece today and see if they have any of these go fast editions up there that don't have the sensor either. :D
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
No the baro sensor does not have the short pigtail. Only the MAP sensor does.
This is all 04-05 LLY specific/unique stuff.
13,752
822
I know. I was talking about the MAP sensor. By "that plug", I was referring to the one that connects to the MAP sensor pigtail. The one he is holding in the last picture. I guess I should have been more clear in my post.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Not yet. Waiting on my twin parts to get done at the powder coater then I can put it back together. Hopefully I'll get to have it back together Sunday and give it a shot. I've got an edge insight so I'll be able to actually monitor what's going on while I'm cranking it.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Well got it back together but still nothing. Just crank and crank.
I'm going to see if i can wire my CTS to stay on while it cranks so I can read RP.
Click VV
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Really? Even while i'm cranking it. That would make life simple, i'll try it later thanks. :thumb:
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Tried it, no good.
I think i'm just gonna bring it over to Fleece and let Brayden work his magic. I know it's something stupid.
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
did you have the fuel system off, maybe a ton of air in the line. Had that problem with an lbz once, thing would crank for days and then once it finally started.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Yea i put ALL new lines on the truck. That's what I had thought at first but didn't figure on it taking so long to get out. If that was it, it's nice to know I didn't screw anything up.
Side note; Anyone every notice their oil pressure higher than normal after twins? At idle i'm seeing anywhere from 35-60 psi at idle.
