Oil in coolant
thunder550
1,176
Phoenix, AZ
I have oil in the coolant in the motor I just did HG's on. Hoses are soft after sitting, so I don't believe it to be a HG problem. What are my other possible sources? Just the oil cooler? Thoughts?
Engine oil level looks low too. Going to pull the drain plug to be sure I don't have coolant in oil as well. Will report back in a few.
thunder550
1,176
Phoenix, AZ
I did not change it, but I did pull it off to replace the o-rings.
Engine oil looks fine.
Coolant smells like trans fluid. Checking that next.
A. Stock Lbz
Aug 13, 2013
342
spokane wa
that would explain the pink looking coolant. everytime i have had coolant and oil mix it has been the brownish milkshake color. good luck i hope it is simple, bada$$ truck man
thunder550
1,176
Phoenix, AZ
I've only put 5-10 miles on the truck since I got it running again, I hope that's not enough to do any real damage but I'm not going to hold my breath. Left Mike a voicemail and sent him the picture above, will see what he says.
6,052
I have an odd feeling this was your issue prior to pulling the engine.....
6,052
No but your nasty looking coolant might have been an indication
thunder550
1,176
Phoenix, AZ
The coolant didn't look milky and didn't smell like trans fluid like it does now though. I am wondering if the HG/overheating issue pressurized everything enough to cause a crack or break in the trans cooler?
thunder550
1,176
Phoenix, AZ
So just a coincidence that the water pump failed at the same time? I understand what you guys are saying, just having trouble reconciling it in my head with the water pump impeller at the same time.
6,052
It may have just occurred when you put it back. Just seems strange it started as soon as you got it running. Maybe you bumped the radiator just right
Yngdmax92
962
I agree with thunder550. His coolant last time was extremely dark like actual oil in coolant. This is a separate problem that might been caused from the extra pressure of the leaky head gasket.
6,052
Yeah I was thinking about that, that's why I made the comment
