611
At almost 200k miles started to pull left.. And skidish off center later is probably due to fresh springs in the rear that raised the truck ~2" and pulled couple ° of caster out
minerigger
2,660
Casper, WY
Removed the 366 kit and up pipes. Moved the wiring harness all over and moved the ac compressor. Installed my new DHD super high flow fuel block and lines along with the 1/2" cp3 fitting. Got bridge in as well. Just need to finish up running the new fuel lines, put in ported rail fitting and fprv shim kit then install the new 68 stg2r
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Got mai box!
Hopefully it warms up a tad this week so I can get to work installing it. :thumb:
04chase
222
last few days i have done
5" magnaflow turbo back in black
Cognito stage 4 leveling kit with fox shocks
rare parts tie rods
new pitman and idler arms
Efi live with dsp5
precision ez solid billet grill
leds exterior and interior
edge cts monitor
led 3rd
new intermediate shaft
Sitting on the shelf
escalade handle
ss tail gate spoiler
chrome rear handle with painted trim
Denali projectors with morimoto retro fit
Led tails waiting to be smoked
Bmf novakane w 305/55/20 nitto m/t
sulastic shackles
mag hytec cover
merchant pump rub kit
led interior/dash with new gauge face and escalade needles
egt for cts
ill be busy for the next few weeks.
Tyler_LBZ
96
NC
Bled all the brake fluid and put new fluid in, used the air compressor made it an easy one man job.
Needed it bad lol
New fluid on the left, old fluid on the right
Tyler_LBZ
96
NC
rare parts tie rods
Efi live with dsp5
edge cts monitor
led 3rd
escalade handle
sulastic shackles
mag hytec cover
egt for cts
Nice collection of parts, Ive got rare parts tie rods coming in the mail so I will be putting those on in the next couple weeks.
Let me know how the shackle install goes. I'm thinking about getting a set of the sulastic ones
SoCalMike
760
SoCal
Broke the coolant bypass dealio in the coolant hard pipe...FML not gonna be dome tomorrow now
That sucks. I just found out my UCA ball joint boot is busted...... Going to order Moog uca's. The ac delco uca's have a bad design on their ball joint. Only 2 months old........
minerigger
2,660
Casper, WY
I noticed on my cognito uppers that the boot portion has slipped off the sealing surface if you want to call it and there is grease everywhere...for the price of them I don't much care for the ball joint design, the arms are ok though. But at some point mine will be coming off for the moog uppers I have
02greysixer
1,829
North Central FL
Finished up my interior. Wow what a difference that mat made. Definitely worth doing. I did a double layer down the tunnel and in both front floor boards. It even covers up most of that annoying gear rumble from the solid flywheel.
