Rikter
Grumpy, old, farty, funny
Jan 14, 2010
61
Calgary
Stuff Done
60 hp BD injectors, heads & ARP studs, PPE manifolds, up pipes & MBRP down pipe, EFI Live Tune w 5 knob, Sinister Diesel intercooler pipes, AFE Turbo neck inlet, 150ghp FASS lift pump, new Suncoast 6sp, torque converter, Fabtech Tie Rod ends, Edge Insight Monitor, new water pump & starter, hoses. Awesome Aluminum Bash Bar by Bandit. So now to do the "$5 dollar bill on the dash trick" that the Corvette guys do, I have to first tape it down to the dash. 'Cause it'll just fly off the dash when I hit the throttle. Plus they are usually screaming by the time it gets into 2nd gear and just want out of the truck (or they are speechless). Too bad its winter here now & I really can't use all the power it has now. (Seriously! Holy Bat C&@$P does it fricking go!)
bevi
Jan 17, 2010
709
Nh
Got my piller gauges in the mail, put my spy's back on now that the roads are a little less salty.
kirkland
Apr 7, 2013
145
Oklahoma
Finally broke down and bought a FASS 150... Should be here Tuesday and picked up some new wheel bearings to hopefully tighten up the front end...
kirkland
Apr 7, 2013
145
Oklahoma
Well new pitman arm, idler arm, steering stabilizer, inner and outer tierods with sleeves.. FASS titanium 150 installed and that solved the stutter under full throttle she's all there now
dmaxman06
May 25, 2011
493
morenci az
havent yet but going to tear down the t case is the wifes lbz in a few and install the pump rub plate and tcase brace and magnitic drain plugs should be a fun afternoon
baddaddition
Mar 10, 2013
287
Well went to change the oil today and once on the lift I realized my down pipe was broke in two...... so before fathers day dinner I ripped it out and welded her back up. No more rattle either..huh go figure!:cool:
Parker_
I'm a torque addict !!
May 13, 2014
244
Blythe ca
Are u putting urea down on ur yard ?
kirkland
Apr 7, 2013
145
Oklahoma
Random question I know but ur lawn looks killer ! I guess btw nice truck to haha
Thank you, I mow it but I got tired of my neighbors lawns looking better than mine so I have a company come out and treat it and all I gotta do is hope it rains .. Because I can't ever remember to go outside and water it lol
5,933
Tore my tcase down over the weekend and found a few bad parts. She needs the updated shift fork and hub, a new output bearing, throwing a new mode fork in for good measure and put her back together.
And no pump rub on the second case half after 90k (i replaced the case half once after pump rub took hold). Helps the steel tab is still in tact
Parker_
May 13, 2014
244
Blythe ca
Ordered efi live for her today . Very excited and hope it helps me with egr codes and some added power
Emanlb7
May 18, 2014
Alberta,Canada
Mounted new rims/tires in prep to remove lift and lower it in two weeks. Gathering all parts required including new front diff half and bearing kit.
