Kamilmk
420
Seymour, CT
Oh you know...
Getting ready to pull motor. And off it goes to a machine shop. Bent rods. Possibly cracked pistons.
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Changed ATF spin on filter and changed ATF with fancy transynd
Damn old fluid was still red, pampered truck :eek:
minerigger
2,660
Casper, WY
Heard that. Mine is getting an oil change in a few weeks and only has 1200 miles on the oil but is 18-19 months old and sits a lot.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
Finally trying to get the truck out of winter hyberation. Pulled the engine awhile ago to redo the oil pan gasket, found a broken piston oil squirter, put in a new lbz water pump to fix a leaky one, ported the turbo pedestal and manifolds, got Ricks tow flow up pipes, Levis up pipe and manifold blankets, and I am going to replace the main seals. Hopefully it will be running this weekend, as it needs to start hauling trailers next week.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Killer work space you got there!
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
Thanks, I defently don't miss doing it on Jack stands like back in the old days.
Got the motor back in the truck, hopefully tomorrow I will have it mostly back together. I Zaks heater hose mod and need to get fittings on Monday. Does anyone know what size the heater hose is? I am hoping to replace with a single piece of and route it around my the fender to make room for compounds.
SoCalMike
760
SoCal
Finished my lift. Well sort of. My torsion bar bolts and nuts stripped. So I need to order them and install. Adjust the front end height so it about level with the rear. Even with the bolts out it's very close to level.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Been thinking about selling it again, so I washed it and wanna keep the ole pig now. Changed the oil, cleaned the MAF, and blew the air filter out the other day. Trying to pinpoint why I’m getting 14mpg currently. Next is change the oil filter, clean the air filter, and find a CTS so I can monitor my coolant temp and fuel pressures.
Jacy_dzlguy
lots to learn...
Aug 27, 2011
257
32
South Florida
If you’re serious about selling let me know :thumb:
Awenta
4,090
CT
Timken quality right there! About 700 miles on it.
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
I've got over 170k on my vato zone timken replacements. You just got dealt a shitty hand, sorry for the bad luck....
Sent from my SM-J337A using Tapatalk
mac2881994
47
Took most of this week off work and took my time getting the heads off. Motor has just over 250K and I started noticing a little bit of leakage from the upper radiator hose. This led to the discovery of a hard hose in the mornings and bubbles in the expansion tank. New HGs are here and the heads are at the local machine shop. It will also get a new water pump while it is apart. Going back together with studs.
