Digmax
289
Check under the hood frequently to lame sure everything is looking I and sounding ok. Still cannot figure out how this is happening. Just out of nowhere it does it...
On our equipment when that happens it's nearly always the tensioner
Sent from my SM-G935V using Tapatalk
830king
191
Central MN
Maybe I'm seeing things but it looks like the tensioner isn't tight, looks like a little residue on the underside from movement? Maybe worth checking that out.
Sent from my SM-G930V using Tapatalk
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,203
363
At Da Beach
Power steering pump pulley could be moving and slipping it off. My 7 did that right before the pump locked up...
Awenta
4,090
CT
You got the new pulley with the sides didn't you?
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
The tensioner is tight and the pulley has the tall sides. I got a new tensioner pulley because it was bad and it didn't have the tall sides and it would throw the belt now it just shifts over like in the picture.the power steering pump does feel weak and the steering isn't as assistive as it used to be in slow parking lot driving but until it goes out it's good enough for me but I never thought that could cause a belt problem.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Mine does the same after big daddy Don Garlits burnouts.. finally let it eat a rib off and its been fine since... no idea what's wrong but I think it's the rpm change
TerryRH
Jan 23, 2017
33
MO
Picked her up from the body shop from where the wind swung the door and dueced everything up
Sent from my Pixel using Tapatalk
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
Haha I I don't do burnouts but I guess I could cut a rib off its almost about to split off anyway
NC-smokinlmm
May 29, 2011
5,203
363
At Da Beach
My 7 starting to wear belts first, then randomly throw them off. I replaced everything else and it still slipped the belt. Every once in a while I would loose power steering for a split second at idle in parking lots. I could see the power steering pump pulley was out of alignment. I put a new pulley on it and it lasted about 1,000 miles before boom. The pump was locking up and the pulley was spinning on the shaft, once I pressed a new pulley on it wasn't going to spin so it locked up and exploded. This was all over about 5,000 miles so it's a slow death, especially if you only drive it once a week. Lol...
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
Good to know you pretty much described what I'm going through haha
