04chase
222
Put a lml hydrobooster in
Upgraded ps pump with high output psc pump
Made new high pressure lines with hydraulic hose (replaced leaky crimped oem lines) welded jic fittings on hard lines.
Flushed fluid with royal purple synthetic.
Adding a ps cooler too
Put a stock tune on it to pass smog .
Now to finish putting egr mods back on and finish pcv re route.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
When I had the JIC fittings welded on mine I noticed the pressure line from the pump had been tightened up against the can and was partially wore through, the can had some wear marks also. No time to find a new/used hardline no leak to date and have since found a replacement just in case...
I did notice that when the above line is cut apart there is what looks like a spring attached to it and it goes inside the flexible line. Turns out it's not a spring but a restrictor to keep the pump from overrunning/overwinding.
Not mine but from another site
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,225
370
At Da Beach
Paint matched GMC logo, debadged tailgate except for Denali emblem. Going to order amps Monday. I think it will look way better without the factory steps. What do yall think???
NC-smokinlmm
May 29, 2011
5,225
370
At Da Beach
Couple quick pics, she is dirty as hell...
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Tried to squeeze another cooler in the stack... Barely fits :D
The grille... Now that's another story, working on a solution...
Dozerboy
4,919
498
TX of course
That or something else for sure. I like wheel to wheel steps. You could go with stainless, but I think black or color matched would look better.
NC-smokinlmm
May 29, 2011
5,225
370
At Da Beach
I've decided on Amp steps, I like how the truck looks clean without boards, but im only 5'10" and my wife is 5'6" so I have to have them. I'm kicking around the idea of getting the stainless trim and trying something diffrent with them...;)
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Pulled trigger on new wheels and tires, after five years of saying I should. :roflmao:
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
Do you have a parts list?
I could possibly put one together, most of what I got is from sledhead's diy thread..the choice of cooler is key though if you want it to fit up front. Mine barely fit above the trans cooler and I had a shit ton of trial and error to get proper fitment.
NC-smokinlmm
May 29, 2011
5,225
370
At Da Beach
Added Fox 2.0 Shocks and cleaned her up...:angel:
