I know how you feel Ed. Between the time and the money spent on these things it can put a drain on a guy.
Agreed!
Well I finally got this thing track ready:woott: I went for a couple test passes this afternoon and all is well! The new much larger turbo spools great! 1st pass I let out of it at about the 200ft mark just to be safe and make sure everything was ok. My rail pressure was down 5000psi from desired. Pretty sure my lift pump is pooched. Gonna get a new one on monday. Second pass I went with a larger tune and rail was down 8000psi and then I blew an intercooler boot. I'm pretty pumped about how this front mount turbo works. I'm going to do a third gear start next hook to get my charger spooled a little better on the line. Here are the two videos from today!
1st hook:
http://www.youtube.com/watch?v=bASQ908THUE&feature=relmfu
2nd hook:
http://www.youtube.com/watch?v=a0Cs0Ug3hqE&feature=relmfu
Definitely sounds good and gets up on the turbo quick! :thumb:
DH 1.0 is stock apearing over 700 HP and DH 2.0 is out there getting the bugs worked out of the new charger set up.So DH1.0 still lives?!?! How is DH2.0 doing with new owner?!?!
