Noise on driver side when hot
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Sweet 212°F Trans temps today...
If I am driving and it does it, right when TTC slip goes to zero (locked) the noise goes away. :confused::confused:
Mike, Is my 1058 still under warranty?
slowlmm
Mar 2, 2008
2,582
46
so cal
sounds the same as my 1058 especially if it goes away after it locks. mine started makeing the noise when i started haveing the other issues with my converter. sounds to be a simular issue.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
Does it only happen when jackie rides with you??
Maybe the noise your hearing are the guys yellin WOOOO HOOOOOO!!!
That explains why it only happens when its hot out too, she prob wearin less clothes than usual.:D
02bigstrokin
Sep 9, 2008
882
tell me about it, Wish I could hire someone to ride in the engine bay and track it down while I drive :rofl:
hey me and travis did that chasing a sound on my truck, he rode on the front with the grill out standing on the bumper and we went around the neighborhood with the hood up.:rofl: i felt like ace ventura driving.
2,049
That is one of the nuttiest things Ive ever heard.
Mike, IMO its the converter. Only way to know for sure is to have ML look at it.
15,681
233
Are you sure it's not the hydroboost making the whining sound? Allison pumps and converters do not make noise since '01. I think the converters are warrantied for 2 years if I remember.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
I'll check that Mike. I noticed trans temps climbed over 200 and that when the noise would start, so I started watching the TCC slip and playing with t/h and seemed like it would go right away when converter locked. I need to crawl under the hood and dig around and see if if I can find anything that looks loose or leaking. It almost made the same sound as when we had the EGR blocker plate (up pipe) bolts too loose, but it was down by driver side and a little different and tone changed with rpms, even when you let off and it would slow down as the rpms came down it would slowly change tone.
also it only does it when it is hot as hell and then the fan engages and when the fan runs it sometimes is there.
lexcar
Jul 28, 2009
I notice there hasn't been a post on here in a while.
Did you find out where the noise is coming from?
I have a new body style 07 Sierra with about 25,000 miles on it and it just made the whining noise last week. I was towing up a steep long hill, the clutch fan had been running for a bit then all of a sudden a loud high pitched "whirring" type noise wound up.
I think it is related to the clutch fan but why it would make this noise out of the blue beats the hell out of me!
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Still dont know. I confirmed it was not the converter.
It only doese it when hot enough for the fan to engage. and only sometimes. Almost sounds like it could be a bit of an exhaust leak cause it comes in at high boost, but it still will ONLY do it if the fan kicks in....
lexcar
Jul 28, 2009
I suffered with the noise all summer and then the other day I decided this is B.S. and crawled under the truck. I noticed that the clutch fan which is plastic was worn on the edges of the blades. I popped the hood and found that the plastic shroud mounted on the rad had a missing bolt, so what was happening is at higher rpm the fan was drawing in the shroud and making contact.......plastic on plastic created the loud siren type sound. GM replaced the fan and he noise is Gone.
