No cruise control
1,941
Because whatever scan tool you were using wasnt set up to read ABS codes, yet your autocal was.
Racerrich08
Oct 6, 2019
Michigan
This is the scanner I have and it has the abs
Sent from my SM-G965U using Tapatalk
dndj
Boost!
Apr 13, 2019
302
Oregon
OP - so what was the actual DTC code your found? Please post back if you got sorted this out, for the benefit of the DD community.
dndj
Boost!
Apr 13, 2019
302
Oregon
C0035 c0040
Left front and right front wheel sensor. Odd that both would be bad at the same time. Is the ABS indicator illuminated in the cluster?
Oversize tires? Also try and clean/retighten the EBCM (electronic brake controller module as GM calls it - commonly known as the ABS module) ground located on the frame beneath the driver's side door. This is a fairly well known trouble location due to weather/salt exposure.
dndj
Boost!
Apr 13, 2019
302
Oregon
Have you tried clearing the codes? Do they come right back? ABS codes only get set for wheel sensor troubles the vehicle speed goes over 8 mph.
Oversized tires?
