Yeah, a .040" jet is 1/3rd the size of a .070" jet. So it's about 25hp. Not noticeable.
You should not spray a "real" shot lower than 2500rpm, since that is our lowest racing RPM range. Make sure you have something in place like a pedal switch, EFILive, brake light switch, etc, to prevent it from spraying while staging. You will jump through your brakes, and can break trans parts if that happens.
The simplest method is to hook a baby solenoid directly to your horn. When you hit the horn, it sprays. No real wiring.
25hp? Dont know Pat I picked up 4 1/2 tenths and 5 mph with just a .045 jet.
