Could you PM me a price also Dan?Thanx Dan, Could you PM a price?
Is anything different with the turbine side?
I just put one of these on an a 04 lly tonight, I havent had a chance to drive it yet, so I will report back tomorrow. I am sure I will have to make some tuning changes, so we will see what comes about. By the way I dont have a dyno nearby, so I cant give any hp numbers.
:nopic:
compressor map
How do you read one of these??
Looks very close to a 4088R. Little higher pressure ratio but seem to make almost the same amount of air
Basics:
Pressure Ratio - 1:1 is no boost. 2:1 is 15psi boost. 3:1 is 29lb boost. 4:1 is 44lb boost. Numbers rounded.
Lb/Min of air - How much weight of air is pumped into the engine. A normal hair on fire "tune only" truck will use about 75lb of air at 3200rpm at 32psi boost if my data is right. We routinely run turbos WAY off their maps, so take the limits with a grain of salt.
Dashed line on the left: Surge line. If you try to operate the turbo to the left, it will choke on the air and "pulse" sharply. Turbo bark is a form of surging. It destroys turbo bearings.
Islands: Efficiency levels. The more efficient, the less heat is developed boosting the air, and the less drive pressure it takes.
RPM Lines: Diagonal lines for turbo RPM. Overspeeding is the #2 cause of diesel turbo death when racing (EGT's are #1). But you can overspeed quite a bit before failure.
Dan, can you PM me a price when you get a chance? How hard are these turbos to spool compared to stock? Do these turbos have the same water cooling and sensors etc as the stock turbo? Thanks.
Is there a formula for figuring out "boost pressure-turbo speed-lbs of air per minute"????
Yes. The turbine wheel is a High flow design that is specifically made for AVNT's (not a 40/88 turbine wheel that will fail when used is a AVNT, as some have seen and most will see with the modded stock chargers) Also the veins are of a high flow design.
